Changing gears to 4.88... rear locker or LSD... thoughts?
Discussion in 'General Tundra Discussion' started by tat2ude39, Apr 20, 2015.
  1. Apr 20, 2015 at 3:52 PM
    tat2ude39
    tat2ude39 [OP] MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    So I've been doing a little reading up on these mods and hear that when adding mods that increase the trucks overall weight, including up-sizing tires that a gear change will do wonders for getting the power back and get you back to the proper shift points. Has anyone gotten into this yet? Also, reading up on the LSD button for my 15 Tundra, as it's explained is more less just basically a soft traction control device and really won't 100% lock in when extreme demand is needed. Any truths to this that anyone can shed more light on...?
    SoCal619 likes this.
  2. Apr 20, 2015 at 4:47 PM
    tat2ude39
    Robert
    San Tan Valley, AZ
  3. Apr 20, 2015 at 6:11 PM
    Mike Tread lightly.
    south carolina
    ARB is a EXCELLENT set up ( there arb bumper on my tacoma has proved itself TWICE already) ...
    im planning on doing it to my tacoma not my tundra. If it gets deep i will tell you like this the arb is not afraid to SNAP CV AXLES in half. There is a test on youtube showing how strong they really are. I was very impressed to say the least.
    Problem with todays trucks is the ECM/transmission/ brakes/ABS ,,, all talk to each other now.. When it comes to extreme off-road when you would really use the ARB lockers it might come up short.. The arb is designed to give MAX torque to the wheels. Problem is simple with todays trucks the computer sees a wheel slip when its not, engaging the brake when in effect its HURTING what the locker is designed to do. Now you have a power struggle going on here not good when you need max torque.
    If you could disable the units from talking so the brakes(abs) would apply during arb locking it would be ideal set up.
    tat2ude39[OP] likes this.
  4. Apr 20, 2015 at 8:29 PM
    I think it would benefit you to regear at 37"+ tires. You can push the 35's without issues. There's a couple of members here @Ron Burgundy who has a 7" lift on 37" tires.
  5. Apr 20, 2015 at 9:37 PM
    tat2ude39
    Robert
    San Tan Valley, AZ
    Mike and T-Rex266 like this.
  6. Apr 20, 2015 at 9:48 PM
    Mike Tread lightly.
    south carolina
    cool looking pro man.
