Changing Fuel Filter- How much fuel should drain out?
Discussion in '1st Gen Tundras (2000-2006)' started by seachunk2, Jul 5, 2019.
  1. Jul 5, 2019 at 1:04 PM
    seachunk2
    seachunk2 [OP] New Member
    2004 Tunda DC V6 4WD SR5 AT
    I needed to change rusted out fuel lines that run from the fuel filter output to the Pulse Damper on the fuel rail. I wanted to install a new fuel filter. I disconnected the battery negative, fuel pump relay and loosened the fuel cap. I loosened up the fuel line on the input side (coming from the tank) and about 3 quarts of fuel came out with no end it sight. I expected to see only about a quart come out. I reconnected the fitting to the filter to stop the draining for now.
    Unfortunately, I realized I had a leaking fuel line just after I filled up the tank so it's as full as can be.
    How much fuel should drain before it stops?
  2. Jul 5, 2019 at 2:38 PM
    Professional Hand Model
    Hand Protectors
    @bmf4069 did his fuel filter replacement and reports the same problem you’ve experienced with massive amounts of fuel pourings.
    Not sure what to tell you other than let her drain until it stops. Or run the tank dry by driving and then let her drain till dry.
    Aerindel likes this.
  3. Jul 5, 2019 at 3:18 PM
    seachunk2
    I can't run the engine. The fuel line going to the damper fitting was spewing a lot of gas. Of course this happened soon after I filled up the tank. I already have that fuel line removed. What is left is the fuel line going from the filter's output side to the fuel line that I already removed. These two lines connect by the wheel well between the battery and firewall. I am replacing both fuel lines because they are both severely rusted and the filter since everything is going to be apart. I don't know how old the filter is. It could be original. The Tundra has 213K miles. I bought it this past December.
    There must be a siphoning action going on because the fuel line coming from the tank can't be holding more than a pint or two of fuel.
  4. Jul 6, 2019 at 10:14 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Maybe try putting your gas cap back on and see if it stops.
    I remember mine kept pouring out and kept messing with the gas cap till it stopped. Can't remember what the solution was (on or off).
  5. Jul 8, 2019 at 10:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That damn thing. I HATE that fuel filter. NOTHING you do will stop the fuel from leaking. Flip the damn truck over to change it or take it to someone.
  6. Jul 8, 2019 at 10:16 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Who the hell puts hard lines going into a filter anyways? I hope that engineer enjoys his spot in the deepest darkest recesses of hell.
  7. Jul 8, 2019 at 10:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Fuck that filter.
    Darkness, Sangre Kid and TX-TRD1stGEN like this.
  8. Jul 8, 2019 at 11:59 AM
    Hand Protectors
    I never realized how hard a swap it was until you mentioned it and then I started researching it. I’ve paid a shop to do it twice in the past for like $50 each time. Sounds like a deal, but they were doing other work on the truck as well.
    Someone here was saying there is no need to change our filters, but I think its a good idea.
    Sangre Kid likes this.
  9. Mar 28, 2021 at 9:20 AM
    BobTTundra
    BobTTundra New Member
    Bob
    2004 Tundra 4WD TRD Limited
  10. Mar 28, 2021 at 9:27 AM
    Hand Protectors
    Pics of gnar gnar filter with approx 30k miles. Brand unknown. Frame bracket is the original Toyota.
    Check out the Gelatin Finger which evidently was resting internally on the bottom of the housing on the inlet side. Look at the Brown Gas Fluid which squeezed out with a push of the screw driver on the paper roll.
    RustyShackle323 likes this.
  11. Mar 28, 2021 at 8:00 PM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    You guys are just talking about the filter in the frame rail right? 2 14s and a 19 to hold the filter. Hmm must have been lucky. Mine changed easily and only drained fuel for probably 30 seconds.:monocle: I also agree that it is definitely a good idea to change. There are a few clip like things that hold the fuel line into and out from the filter in place that if you pop off it is easier to maneuver the filter out and in.
  12. Mar 28, 2021 at 8:02 PM
    I changed mine out. Don't recall losing that much gas. I unscrewed the fittings from the old one and screwed it into the new one. I didn't wait around to see how much gas would leak out. A finger over the hole until it mated with the new filter was enough to keep from exsanguinating my fuel tank. There is zero reason not to change the fuel filter. That's like saying you shouldn't change your transmission fluid just because you have a "sealed" transmission. :boink:
  13. Mar 28, 2021 at 8:08 PM
    terrward
    terrward New Member
    2004 DC SR5
    Are OEM filters the way to go or do most people use aftermarket filters like wix or purolator good enough
  14. Mar 28, 2021 at 8:09 PM
    I used an aftermarket filter that I got from Napa. Which is likely a Wix.
  15. Mar 28, 2021 at 8:15 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    I also got a wix
  16. Mar 28, 2021 at 9:48 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Same thing. Had no problem changing it in about five minutes. Not sure if it made a difference or not but my truck sat over night before I did it. Only half a quart of so of fuel came out and that was it.
  17. Mar 29, 2021 at 6:00 AM
    Hand Protectors
    I think the Wix Premium might be the way to go because I’ve never seen a reviewer here or elsewhere say they had any problems with the threading leaking. My old one looked like it *might* be a Wix due to shape of body.
    Reason I went Toy OEM this time was for the new frame bracket and shiny little Toyota Sticker reflecting back at me. I did read some reviewers bitching a little about leaks, but caulked it up to DIY Manglers who like to complain a lot. :rofl:
    I found out they were right, but still came out with a Win with the Gas Teflon Tape. :thumbsup:
    The Ear Plug Method for the Win!:thumbsup: Great idea.
  18. Mar 29, 2021 at 6:16 AM
    Odd these would leak. It should be sealing at the flare fitting, not the threads.
    FrenchToasty likes this.
  19. Mar 29, 2021 at 6:19 AM
    Hand Protectors
    Yeah. Odd is correct, but Pipe Thread Sealed the Deal.
  20. Mar 29, 2021 at 6:20 AM
    I would be leery of this. Using teflon tape on flare fittings is not recommended. But hey, if it works, it works.
    JohnLakeman likes this.
  21. Mar 29, 2021 at 6:30 AM
    Hand Protectors
    Yeah. Made for Gas Teflon Tape so no worries there. The Flare is possible leaking at the threading where it mates to the Filter. Needed just a little change in Mojo with the Tape blocking the thread path. No worries here as it has been holding fine for a few weeks, but I’ll report back if it does!
    Another theory is that these Aftermarket Filters change the Flare Line Mojo ever so slightly (widening) and when returning back to OEM the Flare is off ever so slightly. Always had shops do my work and you know they NEVER use OEM parts unless its Stealership.
    I feel good about it.
  22. Mar 29, 2021 at 7:38 AM
    peanut likes this.
  23. Mar 29, 2021 at 7:54 AM
    Hand Protectors
    Correct.
    Leak (in my case) was very slight weep coming from threads on one side only. Success on the other side without tape (but removed and taped both sides anyways). I could have cranked on the unit, but being highly trained in Sensory Hand Mojo I know where the Mangle Limit is before getting there.
    Other option was stop and run around to autozoned (with gas leaking) for a Wix or NAPA or try the Gas Tape for the win. These Flare Nuts are slippery slopes once you go a certain route with them. KISS.
    Filthyphil likes this.
  24. Mar 29, 2021 at 7:57 AM
    BobTTundra
    Bob
    @KNABORES I agree with your diagram of the seal of the flare, that is my recollection from many plumbing projects. I used a little teflon tape on the threads thinking it would act as a lubricant for the threads and make tightening a little more smooth. Also to show God that I really tried and deserve to have no more leaks.
  25. Mar 29, 2021 at 9:04 AM
    If it works, it works. Like my engine ground cable that I scabbed together on the side of the road with the idea of replacing it with the appropriate one when I got home. Took me 2 years to replace it, cause my fix worked. Wasn't pretty, wouldn't recommend it, but it worked. Hell I've got scotch locks and wire nuts in my truck wiring, who am I to throw a stone.
  26. Mar 29, 2021 at 11:08 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Was reading these posts starting to worry why when I changed mine last month very little fuel came out maybe 30 seconds or so and then swapped filter out easy as pie.
  27. Mar 29, 2021 at 12:22 PM
    SouthPaw
    2000 Limited 4x4 AC
    Mine leaked when I first swapped it and I used a Wix filter. I gave the nut one more umph and it stopped. I snugged and then a little more but apparently it needed to be pretty damn tight.
