Changing/Cleaning Battery
Discussion in '2nd Gen Tundras (2007-2013)' started by tnbndr, Sep 29, 2018.
  1. Sep 29, 2018 at 7:06 AM
    tnbndr
    tnbndr [OP] New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Do I have to worry about how long I keep the terminals unhooked while changing or cleaning the battery in my 2012 Tundra?
    Do those 9V backfeed through the power ports work? or is it even needed?
    TIA
  2. Dec 16, 2018 at 10:11 AM
    wh4x4
    wh4x4 New Member
    I was wondering the same thing. I was going to disconnect the battery to clean the terminals. Did you unhook the battery?
  3. Dec 16, 2018 at 10:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I was having issues with my battery corroding in the first year I owned it. I cleaned them up with baking soda and water. Then install those cheap green and red felt washers underneath the terminals. It completely stopped the corroding process. I didn’t even lose my radio settings. I also added some battery terminal protectant. Dielectric grease should work or Vaseline. Can’t remember if it was on the tundra or the other cars but I did lose trip A and B memory.
    wh4x4 likes this.
  4. Dec 17, 2018 at 4:10 AM
    tnbndr
    New Berlin, WI
    I ended up buying the 9V battery backfeed just to play it safe. It's done, lost no settings and truck runs.
    https://www.amazon.com/gp/product/B004BW9J1Y/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    15whtrd likes this.
