Changing 6112 setting?
Discussion in 'Suspension' started by AZ_Tundra64, Jan 22, 2019.
  1. Jan 22, 2019 at 9:34 AM
    AZ_Tundra64
    AZ_Tundra64 [OP] New Member
    2018 TRD CM MGM
    I recently installed 6112s on the top setting with one CB shim on the drivers side, along with CB +2 shackles in the rear. Im running 33x11.50's.
    I'm thinking about changing the 6112's to 1.9 for a couple reasons. Adding some rake back into the truck, less CV angle, possibly smoother ride.
    Is it worth the work?
    matictundra likes this.
  2. Jan 22, 2019 at 9:36 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I prefer a little rake so I think it'd be worth the work. You're also right in that you'll have a little smoother ride at a lower setting, less strain on joints, etc.
  3. Jan 22, 2019 at 11:20 AM
    BehindenemylinesCali
    BehindenemylinesCali New Member
    Rick
    NORCAL
    2018 Tundra Platinum
    Locker Down console safe Bakflip MX4 Spray in bed Bilstein 6112 Bilstein 5160 2019 TRD Pro wheels
    I have the 6112's set at 1.9 with the 5160's in the rear. I'm happy with the ride. Basically it leveled the truck.
