Changed thermostat.. engine coolant still not getting up to temp
Discussion in '2nd Gen Tundras (2007-2013)' started by Rankinstein, Nov 2, 2022.
  1. Nov 2, 2022 at 1:11 PM
    Rankinstein
    Rankinstein [OP] New Member
    Edmonton AB
    2010 Platinum
    So I replaced the thermostat, 90 bucks at napa, then added new fluid ,, I left a bit in the funnel and let the truck run for like 20 mins to make sure all the little bubbles escaped.
    After leaving it run that long in the garage with the man door open, the hoses were definitely hot, and there was steam after I spill/transfer the funnel and left over fluid over to the reservoir lol I also made sure the reservoir was full before I started the truck ,however the hose after my newly installed thermo is still room temp... why
    When I initially filled the rad, the fluid in the funnel bubbled obv from escaping air. Then when the funnels half full and I start the truck and it bubbles a bit more, that tells me my water pump is working.. also can see the belt turn the pulley np.
  2. Nov 2, 2022 at 1:38 PM
    Rankinstein
    Edmonton AB
    2010 Platinum
    Side note, I think there's an issue with the damper controls in the cab.. there is also a 20 second delay after start up for hvac controls to come online. But that was minor compared to my coolant temp gauge not even closely following oil temp. that's why I'm in this nonsense, I don't have heat to defrost windshield and it's starting to snow lol
    But I thought the problem was the thermostat due to my cold hose ... I dont see the cab hvac having anything to do with engine coolant recirculation tho
    knoxville36 likes this.
  3. Nov 2, 2022 at 2:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think you've posted this in the wrong generation thread going off of the 2010 in your username.
    Either way, sounds like you've got some wiring issues with the HVAC cluster. Also, is the jiggle valve oriented correctly in the engine?
  4. Nov 2, 2022 at 2:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    ColoradoTJ likes this.
  5. Nov 2, 2022 at 2:09 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Did you fill the radiator all the way up? Sometimes if there is not enough coolant volume circulating the thermostat wont open up. My other thought would be a faulty thermostat or the coolant temperature sensor but if your hose is still room temp then its just not opening for some reason. I would think it's a volume issue
    Tundra2 likes this.
  6. Nov 2, 2022 at 2:35 PM
    Rankinstein
    Edmonton AB
    2010 Platinum
    Anyone ever flush their coolant? I pulled the plug at the bottom of the rad and drained, then started the truck to get any left over in the system... how much coolant is there in the engine? I was surprised at how little came out after I let gravity finish doing its job
  7. Nov 2, 2022 at 2:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I drained the block on my 2000, and got some nasty stuff out, but that was an unusual circumstance...
  8. Nov 2, 2022 at 2:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What engine do you have?
  9. Nov 2, 2022 at 3:18 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    When you're running engine (after the coolant change) do you have the HVAC set to high heat and the fan bumped on to high?
  10. Nov 2, 2022 at 9:58 PM
    Rankinstein
    Edmonton AB
    2010 Platinum
    So I took out the water pump, it's fine.. I blew out all the coolant lines there's no blockage. The new green coolant I put in came out gross rusty colour pretty quick.. maybe I'll buy flush/cleaner tomo aha.
    Gonna put it all back together and focus on hvac damper servos tomorrow
  11. Nov 2, 2022 at 10:36 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    That could be part of your problem
    N84434 likes this.
