Changed Starter, Now motor spudders and cuts off.
Discussion in 'Performance and Tuning' started by Kurt Z, Nov 10, 2020.
  1. Nov 10, 2020 at 5:30 AM
    Kurt Z
    Kurt Z [OP] New Member
    Kurt
    Need advise please. I changed my starter and now the motor spudders at idle and cuts off. It will rev up when I give it gas while still spuddering. Question is, what did I do that would have caused this because the car ran fine before my starter busted. Air flow? Gas? I believe all my connections are correct.
    YardBird likes this.
  2. Nov 10, 2020 at 6:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Specs, year of truck? You disconnected battery before the install?
  3. Nov 10, 2020 at 6:22 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    If you can keep it running, drive the vehicle for 15-20 minutes and see if the idle and driving parameters have changed favorably.
    The ECU may need to "re-learn" the tune on your engine.
    Just a WAG . . . and it costs nothing to try.
  4. Nov 10, 2020 at 9:05 AM
    Kurt Z
    Kurt
    If I keep the gas going, it will run. I did try to leave it running, thinking it needed to purge out the air in the gas line. I may not have reached 15 minutes but I did run it for awhile, running it up and down from 2 rpm's to 4 rpm's. Didn't seem to fix it. Also. I get this weird thump sound (like a pop) from the motor. It is actually my wife's 2004 Lexus GX470 with the 4.7 liter (I own a 2007 Tundra) both have the same motor. I did disconnect the battery before I took off the starter. Thank you
  5. Nov 10, 2020 at 10:53 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Check all the vacuum lines also. Maybe accidently pulled out one of them while working on it.
    JohnLakeman and Kurt Z[OP] like this.
  6. Nov 10, 2020 at 11:40 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What make of starter did you use for the replacement?
  7. Nov 11, 2020 at 4:17 AM
    Kurt Z
    Kurt
    I just got one from Advance. It starts now. :)
  8. Nov 11, 2020 at 7:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    This ^^^^ is a possibility, but you would need to work under hood for that to happen. If you have O2 sensors on the exhaust pipe down in the starter area, check those for good electrical connections.
    This is about the ECM getting bad or no information for engine control. You've disconnected something, either deliberately or unintentionally, for this to happen, imo. There is no other connection between a properly working starter and how your engine runs.
    RitcheyRch and Kurt Z[OP] like this.
  9. Nov 12, 2020 at 7:51 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    get setup with techstream and pull codes. techstream gives you better info than regular obd readers
    Kurt Z[OP] likes this.
  10. Nov 13, 2020 at 4:17 AM
    Kurt Z
    Kurt
    Thanks everyone for the advise. Last night I tore it all apart and put back together. I let it run (spuddering) until it got up to temperature. Them boom! it caught on fire in my garage! Almost burnt my home down. The Lexus is toast, melted my golf cart and stuff in garage. So I'm done. I will be trying to sell parts later after I clean up the mess.
  11. Nov 13, 2020 at 4:20 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  12. Nov 13, 2020 at 5:41 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Holy crap! That escalated quickly. Glad you were unharmed.
  13. Nov 13, 2020 at 6:51 AM
    Sorry to hear this, glad nobody was hurt and your house is still standing.
    FYI, so you don't get in trouble.....
    https://www.tundras.com/threads/buy-sell-trade-rules.204/#post-2359
  14. Nov 13, 2020 at 7:18 AM
    War Machine
    War Machine SSEM # 5 3MW
  15. Nov 13, 2020 at 9:09 AM
    JohnLakeman
    Dayum. You're making me reconsider the need for a few BA (10# dry chemical) fire extinguishers scattered around the garage. :eek:
    Sorry about the Lexus, golf cart and stuff. Home owner's insurance should help some with the pain, subject to your deductible. :(
    Kurt Z[QUOTED][OP] likes this.
  16. Nov 13, 2020 at 11:06 AM
    jalam321
    jalam321 New Member
    Wow! That is crazy. Sorry to hear that. I'm glad no one was hurt.
  17. Nov 13, 2020 at 11:28 AM
    Kurt Z
    Kurt
    Thanks everyone for responding (caring). I'm still in shock. Last night I was very thankful my home wasn't burnt down. There was so much smoke my daughter thought the power went out. Today I'm like dang, that was a great car and now it's garbage. I will be spending my weekend cleaning up. Just like that in a matter of 5 minutes I lost a car, Golf cart, & blinds. Get a GOOD fire extingwisher near by when working on a car.[​IMG]
  18. Nov 13, 2020 at 11:32 AM
    jalam321
    jalam321 New Member
    I know it doesn't matter now but what do you think may have caused the fire? Maybe loose fuel line that was leaking or something? I'm sure others would like to know also and maybe it will help the next guy out. Again sorry to hear about this unfortunate incident.
  19. Nov 13, 2020 at 11:54 AM
    Kurt Z
    Kurt
    It had to be one of the two gas lines on the right side of the plenum. Either I busted it, didn't completely get back on, or didn't put back on at all. Weird thing is, the car was running (sputtering) but running. I wanted to let it run for a while trying to let it purge out any air and let system work it out.
