Changed Rear Diff Fluid. Is this normal?
Discussion in 'General Tundra Discussion' started by WFD473, Aug 1, 2020.
  1. Aug 1, 2020 at 8:18 AM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    This is what I found stuck to the magnetic plug with around 55k miles. As far as I know, it was the original fluid.20200731_154019.jpg
  2. Aug 1, 2020 at 8:23 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    That's never good.
    Hopefully it was just casting flash, aka extra metal hanging on barely attached. Hard to say really without inspecting actual gear teeth in the dif.
    WFD473[OP] likes this.
  3. Aug 1, 2020 at 8:29 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Those are decent size chunks. I would be mildly concerned. Hopefully someone who knows more than me will come by and put your mind at ease.
    WFD473[OP] and Seafury like this.
  4. Aug 1, 2020 at 9:04 AM
    slongo
    slongo New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    As an ex mechanic I can say that its pretty normal to find a few shavings in the Diff fluid especially if its the first fluid change . I wouldn't be concerned and if you want to put your mind at ease drive it 5 thousand miles and drain it again and see if there is anything
  5. Aug 1, 2020 at 9:44 AM
    Professional Hand Model
    Hand Protectors
    I remember, about 2 years ago, another member posted a similar pic of their findings. Looked almost identical to your pic. There is a reason for the magnet and its done its job catching factory filings.
    Situation Normal (unless your truck is acting strange).
    Orions Dad, Black Wolf and WFD473[OP] like this.
  6. Aug 1, 2020 at 1:56 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks to all! So far it's been acting normally from what I can tell. I remember reading that it's normal for the plug to collect filings from the factory, but I want sure if that looked excessive. I replaced the fluid with Amsoil severe gear 75W90 and will check it in 5k to see how it looks.
    Speaking of which, shout out to @lewi3069 for the Amsoil hookup!! Great guy to deal with and highly recommended.
    lewi3069 likes this.
  7. Aug 1, 2020 at 4:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    As said, that looks like left-over shavings from when the axle housing was drilled / machined. Not completely uncommon on a first change, a bit startling, but no big deal.
  8. Aug 1, 2020 at 6:31 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Glad I could help you out!
    WFD473[QUOTED][OP] likes this.
  9. Oct 19, 2023 at 5:41 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    This is from my first fluid change at 29k in my 2021. I’ve had it since new. I’m assuming factory shavings. No issues or problems.
