Changed fuel pump now truck won't start
Discussion in '2nd Gen Tundras (2007-2013)' started by LouisDasilva, Jan 21, 2021.
  1. Jan 21, 2021 at 6:38 PM
    LouisDasilva
    LouisDasilva [OP] New Member
    2007 Toyota Tundra SR5 5.7 Litre
    Changed fuel pump and starter is stuck on when key is put to on position.
    I Checked cylinoid
    Trying to find diode that may have burnt out?
    Any suggestions?
  2. Jan 21, 2021 at 9:35 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada . I assume you disconnected the battery while doing the fuel pump . Since it sounds like your problem started right after that I would recommend to retrace your steps and see if you find anything that may have come loose .
