Change transmission fluid?
Discussion in '1st Gen Tundras (2000-2006)' started by HappyTrails, Jan 15, 2019.
  1. Jan 15, 2019 at 8:05 AM
    HappyTrails
    HappyTrails [OP] New Member
    2000 Tundra SR5
    None
    Hoping this falls under towing.
    Have a 2000 Tundra with 276k. Do not know if or when transmission fluid has been changed. I want to but have heard at this point new fluid could be a bad thing. Then also have heard with Toyota transmission that should not be a problem.
  2. Jan 15, 2019 at 8:27 AM
    Moved to 1st gen.
    I would have the transmission serviced.
  3. Jan 15, 2019 at 9:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How does the fluid look when you check the dipstick? I would definitely go ahead and do a drain and fill. If it's really dirty I would do it once and then again in a month or two. When you do a drain and fill you only get out around 40% of the fluid.
    Here is a guide as to what to look for.
    https://www.youtube.com/watch?v=o690DovjDAc
  4. Jan 15, 2019 at 9:42 AM
    Whocares
    Whocares Member
    Not only would I drain and fill, Id also replace the filter.
    because_wumbo-truck likes this.
  5. Jan 15, 2019 at 9:57 AM
    Professional Hand Model
    Hand Protectors
    All transmissions benefit from a good service.
    If unsure what to do, then take it to a transmission service shop.
    DIY you could do a pan drop and look at the filter/magnets that allude to the condition of your trans. High metal shavings content, etc.
    A less laborious DIY service is to do a drain and refill. You pull the plug and drain a few quarts and refill. The idea is to slowly replace/refresh your complete contents. Do this a few times over a month and should be good. Use DEXIII as specified.
    A few questions. Are you having problems now? Slipping? Hard shifts?
    Filthyphil, YardBird and ColoradoTJ like this.
  6. Apr 18, 2019 at 11:26 AM
    atl63
    atl63 New Member
    Andrew
    2000 Tundra
    Did you end up changing the fluid? Curious how it worked out for you.
  7. Apr 29, 2019 at 7:29 PM
    HappyTrails
    2000 Tundra SR5
    None
    I have not done anything yet. I keep getting answers both yes and no from mechanics and such. Everyone does agree with changing it out slowly, over time. That is what I will end up doing.
  8. Apr 30, 2019 at 11:28 AM
    Whocares
    Whocares Member
    Heres what I would do and what I have been doing :
    I would use an empty container, fill it up with 2 quarts of new transmission fluid, mark the 2 quart line, drain the old trans fluid into the marked container and refill with the new 2 quarts. Hope thats not too confusing. Do that a few times over a few months.
    speedtre likes this.
  9. Apr 30, 2019 at 3:19 PM
    Hand Protectors
    Good idea, but why not just open the drain plug and drain the 3.5-4 quarts out of the pan (empty it) and refill?
    The entire system holds 12 something quarts so by doing just a pan contents draining (3.5-4qts) you are effectively replacing a third at a time.
    I’m trying to figure a way to do a full change using the suction and line pressure from the transmission cooler lines at the radiator.
  10. Apr 30, 2019 at 3:43 PM
    neirbot
    neirbot New Member
    I do this annually.
  11. Apr 30, 2019 at 3:50 PM
    Whocares
    Whocares Member
    Yes, doesn't matter how much you drain as long as you put the exact amount back in. I should have stated that. Thanks for the correction.
  12. Apr 30, 2019 at 3:55 PM
    Hand Protectors
    Also of note: Our manual states (wrongly) the transmission pan fluid contents as 2 quarts? If I remember correctly. It runs somewhere in the 3.5-4 qts range depending on how long you allow it to drain.
    evanhmn likes this.
  13. Sep 21, 2019 at 2:05 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    After I get service records, and do some more research(to see if 1st gen tundras and 5th gen 4runners share a similar tranny) I will do it with a write up. I did the method of using the discharge off the tranny to pump out the old fluid, stop to refill, then restart the truck to pump more out untill it was cherry red. It was super easy
  14. Sep 21, 2019 at 2:13 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Drain the fluid . Drop the pan and check the condition. Filter is metal mesh screen . If not torn then you should be able to clean and reuse. Fill trans and slowly add more to the fill “hot” line truck needs to be in neutral so torq converter spins to get accurate measure
  15. Sep 23, 2019 at 8:11 AM
    Whocares
    Whocares Member
    Make sure the truck is level
