Change trans fluid...?
Discussion in '1st Gen Tundras (2000-2006)' started by Solid Snake, Jun 13, 2023.
  1. Jun 13, 2023 at 1:47 PM
    Solid Snake
    Solid Snake [OP] The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    This has probably been addressed several times here, but I'm gonna ask again anyway. I have a 2006 AC 4wd. I bought it two years ago and I have no idea of the maintenance history. Shortly after buying it, I got the rear and front diff fluids changed, as well as the transfer case. The truck now has 92K miles on it. Should I look into changing the transmission fluid? I've heard that after a while, its just best to leave it alone as long as you're not experiencing any problems shifting or whatnot. I am not experiencing any transmission issues. Is it best to just leave it at this point?
  2. Jun 13, 2023 at 4:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That is your decision. The safest way to do it is slowly, over time, with a series of "drains, and fills." You have the "sealed" transmission which is not as easy to change as earlier models, but still doable for DIY.
    I have changed the trans fluid in all three of the rigs I service.
    • The V6 has 360K miles on it, and has had the trans fluid drained, and filled several times. It also has a jasper trans in it.
    • The white truck has around 300K, and I've drained, and filled at least once with no known prior history.
    • The corolla is fast approaching 200K, and I've done at least three on it with no issues on anything listed above.
    All of my rigs have a trans dipstick. You do not on a 2006.
    I do not have any links for you, but the info is here.
  3. Jun 13, 2023 at 5:25 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    If you’re gonna have problems, it’s generally from minor shift issues that get exacerbated once the fluid is completely changed out. Mostly from clutch material suspended in the old fluid that is helping it to shift somewhat correctly.
    If you have no issues, it’s unlikely they’ll just appear out of the blue unless you put the wrong amount back into it.
  4. Jun 13, 2023 at 6:54 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    If you do not know the maintance that has been done on the truck I would drain and refill, fresh fluid is better than dirty fluid.
  5. Jun 13, 2023 at 7:01 PM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Paging @shifty` paging Dr. Shifty. You have a call holding on the white courtesy phone.
  6. Jun 13, 2023 at 7:19 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I did 12 qts at 168k which is 4 drain and fills. 4 of Toyota WS followed by 8 of Valvoline Maxlife.
  7. Jun 13, 2023 at 8:28 PM
    With how little someone on here said their dealership charged to do a complete fluid change, I can't even imagine bothering with all the work. Sorry, devil's advocate here...
  8. Jun 13, 2023 at 9:00 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    No, I would do at least one drain and fill with Toyota WS. Maybe at the next oil change or service, do another one.
    The old fluid might be fine, but it's not doing the transmission any favors. Most important thing is to set final level properly, so that it isn't over- or under-filled.
  9. Jun 13, 2023 at 9:14 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Measure how much comes out and put that amount back in.
  10. Jun 14, 2023 at 2:04 PM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    What I did and recommend is first just drain and fill the pan. That'll give you a good idea based on color, smell, metallic specs.
    If you have big metallic pieces or it smells burnt and is black leave it alone. If it's brown or brown with a red tint and no burnt smell I'd say you're good to go with multiple drain and fills or a Fluid Exchange via the cooler lines running to the radiator
    *NOT A FLUSH HOOK UP FROM A MACHINE*
    I also highly recommend sticking with OEM ATF. I think 2000 - 03 takes Dexron 3, 04 and 05 takes T-IV, 06 takes WS. Don't take my word as law and CHECK YOUR OWNERS MANUAL.
    Good luck!
    shifty` and w666 like this.
  11. Jun 14, 2023 at 4:11 PM
    If you’re a quart low, this will get you back to a quart low. Better off knowing the drain and fill procedure and how to check the fluid level. 2000-2004, easy peasy, just check the dipstick once warmed up and run through the gears. 2005-2006 with the 5speed, have to check the fluid level through the proper plug on the side of the trans at the right temperature. Eliminate the guess work with proper procedure. Knowledge is power people!! And knowing is half the battle! And every dog has his day and other affirming cliche’s!!!!
    shifty`, des2mtn and Dowloader like this.
  12. Jun 14, 2023 at 4:41 PM
    Dowloader
    Dowloader New Member
    100% Agree, this is the right way to do it.
  13. Jun 15, 2023 at 10:51 PM
    thxcolm
    thxcolm New Member
    central valley, CA
    2001 Toyota Tundra SR5 V8
    Aye I wish I lived where that person lived where a fluid drain and fill is cheap. Here in the CA central valley it was tree'fiddy at the dealer, the kind with no commas ($350). This was for an 01' V8.
    It was mild shock, but I was just not looking forward to being greasy that day.
  14. Jun 16, 2023 at 7:02 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    It was that GD Lochness monster again, wasn't it?!
  15. Jun 16, 2023 at 7:27 AM
    I'd heard $185 and $220 respectively, using Toyota WS fluid, full flush. But then again, I haven't priced it here in ATL which tends to lean higher, so knowing my luck it'd also be $350.
