Change the Spark Plugs?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tridom, Jan 14, 2024.
  1. Jan 14, 2024 at 1:52 PM
    Tridom
    Tridom [OP] New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    I have owned my trick for 11 years. The spark plugs were changed at around 40k miles. It's now at 170k and I've never had a single problem.
    So my odd ball question is: Do I go with my Dad's old philosophy of "If it ain't broke, don't fix it" or should I go ahead and change them taking the chance that it will break (my luck)?
  2. Jan 14, 2024 at 1:58 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    It’s good practice to replace plugs at 100K miles. I prefer using what it came with. Stay away from Amazon since you will most likely get counterfeits.
  3. Jan 14, 2024 at 2:48 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I would change them when I have changed mine the old ones still looked decent it does give you an opportunity to inspect the condition of the plugs are a clue to how the engine is operating. Be sure to replace with Denso
  4. Jan 14, 2024 at 4:12 PM
    Tridom
    Dominick
    Hampton Roads, VA
    LMAO. I bought the plugs a month or so ago and after your post I had to go see what I bought. I guess by dumb luck I managed to buy the right ones. Denso Iradium. Ya had me worried a minute there. LOL
  5. Jan 14, 2024 at 5:40 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Short and simple: change the plugs.
    You'll be happy with the lil' extra pep in her step.
    Metro14536 and Tridom[OP] like this.
  6. Feb 3, 2024 at 6:00 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Well...I knew I didn't want to do this. So far changed 4 plugs. Started the truck just to make sure it would still start... and I have a check engine light.
    Is this normal after changing spark plugs?
    Double checked all the connectors and they're plugged in good.
    Guess I shoulda heeded my dads words. If it ain't broke don't fix it.
  7. Feb 3, 2024 at 6:18 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Ok... so, I put the tester on it and it threw codes 0352 and 0354. Turned it off. Stayed out again and did a rescan. Codes and check engine light went away.
    Looked up the codes anyway and basically they are misfires on cylinders 2 and 4. But how do I figure out the cylinders? I found more than one schematic and they're different.
    But I think I know what caused it. When I changed the 2nd plug I started the truck with one of the coil connectors off (I pulled it off to see how they came off because it was easier to get to than the one I was working on- forgot to put it back on). The truck wouldn't start. I put the connector back on, it started fine, and I went about my business, not looking to see if I had any bad indications. I think the codes and check engine light may have been a result of that and cleared themselves when all was good.
    Canman likes this.
  8. Feb 4, 2024 at 8:24 AM
    Tridom
    Dominick
    Hampton Roads, VA
    Nothing like extra parts. Finished the right side yesterday and started the left this morning. Dropped a tool. Went under the truck to find it and there lay an ignition coil seal. Checked all the seals and they're all there. I knew I checked when I put them in. Wth??? LMAO
    Spark plug change from hell.
    3 to go.
    Only me. LOL:annoyed:
    PhotoNerd and Canman like this.
  9. Feb 4, 2024 at 9:51 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Take your time. You're learning. One of the greatest aspects of DIY. Next time you'll be able to do all 8 in one operation. If you're near Hoover Alabama I'm happy to help.
    WFD473 likes this.
  10. Feb 4, 2024 at 9:53 AM
    Tridom
    Dominick
    Hampton Roads, VA
    Finally done.
    And I'm here to tell you... these tools were a God send to get this done.
    3/8 extensions
    Torque wrench
    Double headed swivel ratchet ( 1/4 and 3/8)
    1/4 Dr ratchet
    Magnetic and swivel 5/8 plug socket.
  11. Feb 4, 2024 at 9:56 AM
    Tridom
    Dominick
    Hampton Roads, VA
    Oh, I spent 26 years working on aircraft, so I am mechanically inclined. Just me and this truck don't get along sometimes. And if it wasn't for bad luck I'd have none. Plus... getting a little old and ornery for this stuff LOL
    BTW... still don't know where that extra seal came from. Pulled the coils and they all have seals.
    Canman likes this.
  12. Feb 4, 2024 at 12:44 PM
    Canman
    Canman New Member
    2007 Crewmax Limited
    I’ll be doing that soon as well, but had difficulty in finding the correct spark plugs.
  13. Feb 4, 2024 at 1:25 PM
    Tridom
    Dominick
    Hampton Roads, VA
    I got them at autozone.
    If you've never changed them, recommend you start on the passenger side, rear. That side is the harder side and the one in the back is the hardest.
    Also hope you're tall. My short azz could hardly reach. LOL
    Also, after playing hell disconnecting the first 2 connectors, I said the heck with that and decided to do the rest without disconnecting them. I was able to get the coils out and moved out of the way while they were connected.
    On the passenger side I did have to take the tops of the air filter box and the fuse box off to get them out of the way. Just wasn't enough room in there.
  14. Feb 4, 2024 at 1:33 PM
    Canman
    Canman New Member
    Thanks. I’m 6’-6” but will still likely need something to stand on as the truck is lifted a couple of inches.
  15. Feb 4, 2024 at 1:36 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Yeah, I'm only 5'6". Even on a step ladder I had to pretty much lay over the fender and engine. My chest and stomach muscles are hurting now from the pressure.
  16. Feb 4, 2024 at 1:53 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Check under your hood for a decal with the correct plugs
    Tridom[OP] likes this.
  17. Feb 4, 2024 at 3:37 PM
    Tridom
    Dominick
    Hampton Roads, VA
    I didn't know that. Wonder if all cars have it.
  18. Feb 4, 2024 at 3:53 PM
    blenton
    blenton New Member
    Glad you got it done! You really must have bad luck; I found this truck to be by far the easiest to change plugs on of any v6 or v8 vehicle I've owned, so long as you have a small assortment of extensions and swivels. I also use a magnetic pickup tool and small section of tubing that fits over the plug end that allows me to turn the plug once or twice to start threading it before putting the socket, extension, then wrench on it.
  19. Feb 4, 2024 at 4:05 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Main problem was my lack of height to be able to reach things.
    Yes, swivels and extensions are a necessity as there wasn't very much room in there.
    I found the magnetic swiveling plug socket was great for hand starting the plugs. It has a built on extension. I just added another short extension to it to extend it outside the hole and it worked like a charm.
    blenton[QUOTED] likes this.
  20. Feb 4, 2024 at 4:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Check the Denso USA website. They have a list of authorized sellers. Advance Auto is one and my regular source. Can't remember about Autozone. Too many counterfeits out there to chance it on a too-good-to-be-true price from an unauthorized source (I'm talking to you Scamazon).
  21. Feb 4, 2024 at 5:17 PM
    Tridom
    Dominick
    Hampton Roads, VA
    I could been mistaken. I could got them at Advance. It was a while back and I do shop at both.
  22. Feb 4, 2024 at 5:39 PM
    Canman
    Canman New Member
    Yeah. I’m up in Canada and we are limited in terms of parts store chains compared to the USA. I went to Canadian Tire and they had no stk, but will need to check some other places. I just don’t want to get soaked for 8 spark plugs.
  23. Feb 4, 2024 at 5:43 PM
    Canman
    Canman New Member
    Nothing is much easier than the straight 6 in my LX450. Lol! I haven’t owned a V8 since my university days (almost 25 yrs ago) when I had a 78 Pontiac Firebird with the 350. That POS put out a measly 175 hp. Haha!
  24. Feb 4, 2024 at 6:11 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    last truck was a ram 16 plugs. dealer charged like 400 labor. i did myself in i think 2.5 hours
  25. Feb 4, 2024 at 7:02 PM
    Orions Dad
    2007 Tundra 4.7L
    If you have access to a top creeper it makes working on an engine much easier
  26. Feb 10, 2024 at 7:48 PM
    Canman
    Canman New Member
    I picked up the NGK Iridium plugs a couple days ago. Will be installing them in the next week or so. I have NGK plugs installed in my 97 LX450 as well as my 1946 Ford flathead.
  27. Feb 11, 2024 at 5:34 AM
    parkerbows
    Jack
    thats what I am going to get. where did u buy
  28. Feb 11, 2024 at 8:16 AM
    Canman
    Canman New Member
    I’m in Canada and got them from Parts Source. They were CAN$24/pair.
  29. Feb 11, 2024 at 11:17 AM
    parkerbows
    Jack
    thanks. I am worried avout counterfeit. found at a napa and with 20% off they are 10 bycks each
  30. Feb 11, 2024 at 3:52 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Napa should be pretty reputable. But I know you can get them at Advance or Autozone.
