Chains on 285s?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Jan 5, 2023.
  1. Jan 5, 2023 at 12:46 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I have a stock 2017 4x4OR with 285s.
    Just wondering if anyone has ever had issues running actual chains on either axle. I have cables too. Don't think I'll need them where I'm going, but planned to pack both sets just in case since I'll have the space.
  2. Jan 5, 2023 at 6:13 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just make sure they go on before your trip... it's always a good thing to practice if there are plans to bring them! You should be alerting as long as you keep your wheels straight...
  3. Jan 5, 2023 at 7:52 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You won’t fit chains up front if you have stock wheels. There just isn’t room between the spindle and the sidewall. Doubtful you’d even fit cables with 285’s.
    If you’re running different offset wheels or spacers, then that all changes.
    kevine0001[OP] and JCBerb like this.
  4. Jan 5, 2023 at 8:06 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    When I had stock wheels 275 65 R18 tires, and bumper I was able to get chains on both front and back. Worked very well, used in 4hi and 4low no issues or damage.
    Now with 35's it's tight (not doable without after market parts) on the front but the back is good.
    HulkSmurf14 likes this.
