Center Console Storage Box USB Charger
Discussion in '2.5 Gen Tundras (2014-2021)' started by tbutler, Apr 2, 2021.
  1. Apr 2, 2021 at 2:44 PM
    tbutler
    tbutler [OP] Team Toyota
    2021 Land Cruiser HE - Black
    I want to install a usb charger to the center console armrest storage box. Can someone point me in the right direction on how to access the back side of the cig lighter? I've searched this site a few different ways to figure out what needs to be removed to access the wiring. Thank you in advance for the help!IMG_9507.jpg
    Njmike13 likes this.
  2. Apr 2, 2021 at 2:55 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  3. Apr 2, 2021 at 3:22 PM
    tbutler
    Ely010606[QUOTED] likes this.
  4. Apr 2, 2021 at 3:26 PM
    Ely010606
    SPARKS, NV
    No prob, yes it has to disassembled when i swapped mine. Good luck .
  5. Apr 2, 2021 at 3:35 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
  6. Apr 2, 2021 at 7:10 PM
    tbutler
    Perfect... exactly the directions I needed. Thank you!
    Njmike13[QUOTED] and 1lowlife like this.
  7. Apr 2, 2021 at 10:09 PM
    tbutler
    It turned out it was pretty easy to take the center console apart. I used a plastic pry tool to lift up the shift surround and the card holder first. IMG_9509.jpg
    Turns out this is a good time to really wipe down all those nooks and gaps while the console is apart.IMG_9510.jpg
    The larger section of the console came up pretty easy with the pry tool. Then I was able to access the wiring and the back side of the cig lighter in the box.
    Made up the wire connections and used a step bit to enlarge the hole for the new charger. Before putting everything back together I tested the outlets - they worked.
    Took the opportunity to wash the console with some soap and water. Dried all the parts with my wife's good kitchen towels. Everything snapped back together. Project complete - case closed.
    Ely010606 and Njmike13 like this.
  8. Apr 3, 2021 at 6:36 AM
    clarkritchie
    clarkritchie New Member
    Ely010606 and Rocko9999 like this.
  9. Apr 3, 2021 at 6:40 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Works for me'...
