Center console lid removal (separate from box)
Discussion in '2nd Gen Tundras (2007-2013)' started by sramirau, Aug 31, 2015.
  1. Aug 31, 2015 at 12:13 AM
    sramirau
    sramirau [OP] New Member
    I damaged the vinyl on the center console lid of my 2007 Tundra. I am trying to remove the lid from the rest of the box in order to drop the lid off at an upholsterer but I am unable to remove the hinges. Any experience on that task?
    HoosierDaddy67 likes this.
  2. Aug 31, 2015 at 4:17 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hey sramirau, check with our vendor Trd Sparks. They should be able to help you, also I read a thread over at Tundra Solutions that might help. Someone here will help I'm sure.
  3. Aug 31, 2015 at 6:00 PM
  4. Oct 23, 2015 at 12:10 PM
    cat972g
    cat972g New Member
    After watching some vi
  5. Oct 23, 2015 at 12:34 PM
    cat972g
    cat972g New Member
    If you have the center console that will adjust forward and on the inside of the lid it has a holder to put pens and tissue, all you need is a phillips screwdriver. First open lid and extend the lid out and have a old rag to put over the latch to keep it from locking. at the back of the lid there is a plastic cover that snaps on( no screws) it covers the back of the hinges. once you have that off you will see two screws remove the two screws which will release the pen tissue holder, which then you will see four screws, remove them and the lid will come off. The hinges will stick straight up, Once you have the lid off, turn upside down and remove the trim.
  6. Oct 24, 2015 at 8:40 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    Good write-up
  7. Mar 21, 2020 at 12:51 PM
    tallguy240
    tallguy240 New Member
    Patrick
    2009 Grey Tundra Limited
    Projector Style headlights, leveling system, LED Fog Lights, LED interior lighting, Toyota emblem projector door/puddle lamps, LED puddle lights in rear view mirrors, Tonneau Cover, Bed LED lighting, 3 inch lift, trailer braking system, and aftermarket audio system.
    These pics can be combined with cat972g's post. I am sending mine off to have a custom upholstry done to it. Hopefully this will help others. Please read cat972g's post and then check out the pics. Note: I have a second gen Tundra and I do not know if this translate to 3rd gen or not.
    1. Remove plastic cover after armrest pulled forward and a rag under the latch to keep it from catching.
    [​IMG] [​IMG]
    2. It will look like this once its removed. It can be challenging to get unclipped. Take your time.
    3. Remove the 2 Phillips head screws.
    [​IMG] [​IMG]
    4. This will loosen the underneath portion of the lid kleenex and pen holder.
    5. Gently remove the kleenex and pen holder which covers the hinges of the armrest. Once this is done remove the 4 screws on the hinges and the armrest is free.
    [​IMG] [​IMG] [​IMG] [​IMG]
    6. Once armrest is removed you can remove the trim pieces on the underneath side.
    7. The rest of the pics are the for removal of the slide mechanism which may or may not be needed.
    Hope this helps anyone who needs to do this. Just take your time and and keep track of the screws and it's pretty easy. Thanks to cat972g for the 'How To'.
  8. Mar 21, 2020 at 2:00 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    GTFO. This is exactly what I needed. I’m in the middle of modding a 3rd gen armrest to fit. Perfect timing
    07 Tundie, SCAC, Rengawt and 3 others like this.
  9. Mar 29, 2020 at 2:52 AM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    lmk if you make this happen
    Rengawt likes this.
  10. Mar 29, 2020 at 6:17 PM
    TemujinNomad
    TemujinNomad New Member
    Looks great. Please do a write up when you’ve accomplished it. Thanks and good luck.
    Rengawt and kparrow like this.
  11. Jun 28, 2020 at 5:35 PM
    tallguy240
    Patrick
    I thought I would post a picture of the finished re-upholster. It took a while to get it back because right after I sent it the covid thing happened. Its back now and installed. I think Kylin Brimhall did an awesome job with this. I think mine was the first Tundra console he had done. So hats off and thanks to Kylin Brimhall for the outstanding work.
  12. Aug 2, 2020 at 10:04 PM
    Geniejohn
    Geniejohn New Member
    2007 Limited Crewcab
  13. Aug 2, 2020 at 10:12 PM
    Geniejohn
    Thank you very much for taking the time to post this. It saved my ass. Checked YouTube and searched google and found nothing until I came upon your post. Thought I would join so I could say thank you. I’m sure there’s a lot of people that searched the net, found your post, and were helped by your efforts, but were not members so could not give you a like.
    HoosierDaddy67 and diavel like this.
  14. Mar 13, 2021 at 3:46 PM
    ggammon99
    ggammon99 New Member
    Greg
    2008 Toyota Tundra SR5
    Excellent detail and photos in this post. The spring latch on the console lid popped out and thanks to this info, I was able to repair it in about 20 minutes. Much appreciated. Thank you.
  15. Mar 13, 2021 at 11:06 PM
    SCAC
    SCAC New Member
    Kevin
    2007 Tundra
    3rd Gen. Frt end conversion. Seats replacement with 3rd Gen. seats
  16. Jan 28, 2024 at 11:42 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Did you ever make this work?
  17. Jan 29, 2024 at 3:05 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    Yeah same here as I was thinking of modding mine to add a wireless phone charger.
