CEL self cancelling?
Discussion in '1st Gen Tundras (2000-2006)' started by Teardrop, Sep 4, 2021.
  1. Sep 4, 2021 at 12:46 PM
    Teardrop
    Teardrop [OP] New Member
    Paul
    2004 Tundra Double Cab
    On the 04 tundra if you resolve a problem that's causing a CEL will it go off on it's own or do you have to manually cancel. If it does how long does it take.
    Also why does the VSC trac and VSC off lights come on for a relatively non-issue like a "very small evap leak".
    Thanks for replies.
  2. Sep 4, 2021 at 1:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    short answer....yes it will go off !
    longer answer from FSM....
    since you quoted "small evap leak", curious if this is a P0442 related code ?
    as for VSC's lights on, they are noted for coming on when certain issues are present !
  3. Sep 5, 2021 at 8:57 AM
    Teardrop
    Paul
    It was P0456.
    However even though I haven't had many cel come up it has always shown the other lights too.
    Thanks for reply.
    BubbaW likes this.
