CEL p050a with a high idle
Discussion in '2.5 Gen Tundras (2014-2021)' started by john408, Nov 12, 2023.
  1. Nov 12, 2023 at 7:23 PM
    john408
    john408 [OP] New Member
    2016 tundra
    Question anyone have the cel p050a come on with a high idle
  2. Nov 12, 2023 at 10:18 PM
    JaredB
    JaredB New Member
    2020 1794 CrewMax
    I would clean MAF sensor, throttle body, and inspect for possible vacuum leaks. If the fuel trim is high on cold starts spray a little brake cleaner around the intake tubes and manifold, if they come down to normal levels you have unmetered air entering the engine in that area. Fog it again and see where you sprayed that made the difference and inspect it
