CEL due to loose gas cap... how long until it clears?
Discussion in 'General Tundra Discussion' started by Maddog94, Jul 24, 2022.
  1. Jul 24, 2022 at 8:50 PM
    Maddog94
    Maddog94 [OP] New Member
    Title says it all basically. I popped a CEL and lo and behold, my gas cap was not screwed on. Put it on to the click and have since started and run the truck a few times.
    Is there something else I need to do to clear the light?
  2. Jul 24, 2022 at 8:53 PM
    How much time has passed? If it's only been a few minutes then I'd let it sit over night. If it's still not clear, disconnect the battery to reset everything. Then if it comes back you know it's for more than the loose cap.
  3. Jul 24, 2022 at 8:57 PM
    Maddog94
    Yeah it's been a few hours. At this point I'll wait until morning and try again. Good idea about the battery, I didn't think of that.
  4. Jul 24, 2022 at 8:58 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If it doesn't clear on its own, stop in at a Napa, OReillys, Autozone, etc... and just ask to use their CEL reader, plug it in and clear the code if you don't have one!
  5. Jul 24, 2022 at 8:59 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Should clear after a few run cycles.
    omgboost likes this.
  6. Jul 25, 2022 at 1:50 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Stop at Autozone.....STOP?!?
    One can only "Step in the zone, Autozone!"
  7. Jul 25, 2022 at 5:40 PM
    Tripleconpanna
    :rofl::rofl::rofl:
  8. Jul 25, 2022 at 6:22 PM
    knewcomb
    knewcomb New Member
    My Tacoma cleared itself after a few days of steady driving.
  9. Jul 29, 2022 at 3:44 PM
    Maddog94
    Update:
    Went a few days and several hours of driving. The light did not go out on its own.
    So I bought a BlueDriver Bluetooth scan and reset tool. The following codes came up:
    P0441 EVAP System Incorrect Purge Flow
    P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
    I assume those are the correct codes that should pop up due to a loose gas cap? Well anyway, I used the reset function of the BlueDriver. The CEL is off and has not come back.
  10. Jul 29, 2022 at 4:22 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Sounds like you got it Doood
