CC rear door speaker wire
Discussion in '2.5 Gen Tundras (2014-2021)' started by kingsxjt, Oct 23, 2020.
  1. Oct 23, 2020 at 7:34 PM
    kingsxjt
    kingsxjt [OP] New Member
    Josh
    2015 Crewmax SR5
    So I’m installing a system in my 2015 and I’m having issues drilling my door bulkhead connector due to clearance issues with the wires. I want to move one small wire on the connector but cannot figure out how to get it out. Anyone know the proper tool to remove this pin and which side of the wire to insert the tool?
  2. Oct 23, 2020 at 8:24 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  3. Oct 23, 2020 at 9:01 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I second this recommendation..
    I bought one like it on Amazon.
    There are several youtubes on removing pins from Molex connectors using whatever you may have around the house.
    Just out of curiosity, what wire is that?
  4. Oct 23, 2020 at 9:04 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    First, ya gotta get those wires outta your butt.
    Lame joke, but it had to be said.
  5. Oct 24, 2020 at 6:03 AM
    kingsxjt
    Josh
    2015 Crewmax SR5
    This is on the right rear door and I believe it is a signal wire indicating the door is shut. It runs back to the actuator plug on the locking mechanism. I will order that kit.
    1lowlife[QUOTED] and Tundyfundy like this.
  6. Oct 24, 2020 at 6:06 AM
    kingsxjt
    Josh
    2015 Crewmax SR5
    Lol. I’ve seen one video by Taco Tunes but it is not very detailed and I don’t want to just hog a drill bit in their and risk damaging a wire. If I move this one wire I will have plenty of room to drill through the bulkhead.
  7. Oct 24, 2020 at 6:51 AM
    BlueRibbon4x4
    Geno
    Yep. That depinning tool will work for ya. I’m sure a stereo shop will sell them too. If you need it now.
  8. Oct 25, 2020 at 12:33 PM
    kingsxjt
    Josh
    2015 Crewmax SR5
    Just thought I’d share that the tool worked. You have to unlock the tab on the outside and then insert the tool on the front side above the Pin and push down. Pins came right out. Thanks for the help!!
