CB/NMO antenna mount question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zero One Actual, Apr 23, 2021.
  1. Apr 23, 2021 at 11:26 AM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    Does anyone know of a bracket or mount that will fit a CB and HAM antenna that mounts in the front left and right corners of our truck beds just aft of the window? I’m trying the ditch light bracket antenna mount currently but I’m having to bend the bracket to still let me open my hood and also not scrape when windshield wipers are on so I don’t think this will work. My next best spot would be the front corners of the truck bed but I can’t find any mounts.
  2. Apr 23, 2021 at 12:30 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I have my antenna mounted at the front of the bed just behind the cab. My bedcover has yakima tracks so I made my own bracket that mounts to the tracks. Without a bed cover it should be easy to make something that attached to the deckrail.
  3. Apr 26, 2021 at 9:06 PM
    Zero One Actual
    I have the Leitner cargo rack system so I will have to look into how much space I will have for something like this between the rear window and the Leitner rack bar.
  4. Apr 26, 2021 at 9:27 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    It does not look like there is much space between the cab and the rack. Leitner does make an antenna mount - would something like this work?
    https://www.leitnerdesigns.com/collections/accessories/products/antenna-bracket
    Another option might be to weld a bracket (or trick tab) near the base of the rack.
    GodlessPro likes this.
  5. Apr 26, 2021 at 10:40 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    If you have the bed rails, Caliraised makes a LED pod mount which should work for an antenna as well exactly the same as a ditch light bracket and you can slide it where ever you want on the bed rail.
    https://caliraisedoffroad.com/products/toyota-truck-bed-rail-pod-mounting-brackets
    Rago makes one that goes by the tailgate Some bed stiffeners also have a mounting hole in the top of them that can be used for lights and antennas or you can make a little bracket yourself that will mount to the bed rail as sr5shark said.
  6. Apr 27, 2021 at 7:17 AM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    I made a plate that goes between my ditch lights and bracket that relocates antenna a few inches inbound. I have CB on passenger side and GMRS on drivers side with no problem opening hood. The drivers side did hit the wiper arm so had to zip tie wire to bracket. Will send pics when I get outside.
    Ryan
  7. Apr 27, 2021 at 7:33 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I have the leitner too. I used the rago mount. It has enough play that I can move it to the bedside when I have the RTT on6D71C62E-B4DE-4F78-8E9E-94A8C2EEC723.jpg
    Zero One Actual[OP] likes this.
  8. Apr 27, 2021 at 7:33 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    This is a standard antenna mount for a CB antenna. Normally, it uses an adapter for a 3/8-24 mount, but I drilled it out to accept a feedthrough and a PL-259 base antenna. I also drilled a couple of holes so it would mount to the Unistrut bed rails. It works well and is rock solid.
  9. Apr 27, 2021 at 1:13 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Pics:
    stiffler and BLONGTX like this.
