CB Front Bumper Shims .250” !
Discussion in 'Suspension' started by FitsofRage88, Dec 2, 2019.
  1. Dec 2, 2019 at 12:24 PM
    FitsofRage88
    FitsofRage88 [OP] real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Toyota Enthusiasts
    9D1A8989-CC71-4A97-B64C-7053CFE4D82F.jpg E0272BC9-110E-4496-A99E-F1538EE8D92E.jpg Installed today the.....
    Washed the Tundra after the install I just noticed my passenger side has more of a gap than the drivers’ side. Needing to ask if Anyone else has some pictures that I could compare on this Tundra forum to see if this is normal or just common with a few Tundras out there again that installed the Coachbuilder front bumper shims’.
    passenger side
    Drivers side
    Again full image so everyone else can see that the passenger side leaves more gap than the drivers side.
  2. Dec 2, 2019 at 6:00 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It is odd. Do you have a before picture? If the bolts all line up I can’t see it being the shims. Unless one side is not fully tightened. But they both look right. Could the bumper be off from the factory? Is that one side damaged? I see holes that the other doesn’t have.
  3. Dec 2, 2019 at 6:03 PM
    FitsofRage88
    Hill Country, Texas
    I’m fully aware it’s not the Shims and Nothing against David @Coachbuilder1. I just noticed this today after the wash and wax it was something that caught my eye earlier today. Nothing damaged per my knowledge it may be the picture.
  4. Dec 4, 2019 at 5:29 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have same issue without shims. Bumper alignment... I think there are some threads to read on.
    TheBeast likes this.
  5. Dec 6, 2019 at 12:32 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting, There are 2 points of adjustment on the front bumper.
    First area of adjustment is from the 2 Rear flanges where the bumper shim kit is installed. The holes are a bit larger than the 4 fixed studs and can be adjusted up and down left and right. Most likely Reveler00 when you installed you pushed up on the driver side first and then tightened the 4 nuts.. then went over to the passenger side and tried to adjust but was unable to move it. If you loosen the nuts on each side and lower the driver side and raise the passenger side this should straighten the bumper out. If you still need some additional adjustment you can do this but loosening the nuts on the front side of the bumper extension. Most likely this won't be needed but is a option.
    FitsofRage88[OP] and 15whtrd like this.
  6. Dec 6, 2019 at 2:06 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    I want to look at mine now but don’t want to know lol. Just like after the forum pointed out the rear passenger wheel sticks out further then the drivers side. Annoys the hell out of me and wish I could unsee it
    TheBeast and Coachbuilder1 like this.
  7. Dec 6, 2019 at 2:56 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Thanks funny, we still have dealerships ask why the tire sticks out on the pass side lol
  8. Dec 6, 2019 at 3:01 PM
    TheBeast The Beach
    do the front bumper shims work on gen 2 bumpers as well ? @Coachbuilder1
  9. Dec 6, 2019 at 3:10 PM
    Coachbuilder1
    David
    Salt Lake City UT
  10. Oct 6, 2020 at 7:15 PM
    FitsofRage88
    Hill Country, Texas
    I still need to get around to this passenger side bumper and get this dialed in what were the other two points where the front bumper can be adjusted?
    Loosened all eight that the bumper shims are attached to and determined all the movement and play there was but still can not figure out on getting it perfectly aligned.
  11. Nov 7, 2020 at 9:08 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    I have the same issue, installed my bumper shims from CB. And my driver side was sitting much lower than my passenger side. Loosened all the bolts and there is no available movement up and down to adjust.
  12. Nov 7, 2020 at 7:06 PM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Called and talked to Dave at Coachbuilder today, he helped me to adjust the bumper. Great customer service.
  13. Nov 7, 2020 at 7:35 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Mine arrive Monday....what did he say incase I have the same prob?
  14. Nov 7, 2020 at 8:29 PM
    The shims move the bumper forward. I'll have to look at mine but there are bolts with elongated slots so that the height can be adjusted.
  15. Nov 7, 2020 at 8:31 PM
    Loosen the nuts inside the aluminum support tube.
  16. Nov 8, 2020 at 5:39 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    @RollTide82 there is a little bit of movement on the factory crash beam, where the shims go, you can adjust them slightly by moving it up and down before tightening. If you tighten with one up and one down it’ll be off.
  17. Nov 9, 2020 at 6:16 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    Alright attempting tonight....I assume I can do this without taking the bumper completely off?
  18. Nov 9, 2020 at 6:17 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Bumper needs to come off
  19. Nov 9, 2020 at 6:18 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    So just pull the grill and such?
  20. Nov 9, 2020 at 6:23 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Grille can stay on. Honestly, you best bet would be remove the 2 splash guards, unplug the parking sensor and fog lights from the truck, and if you have the tools remove the 4 bumper bolts that attach it to the frame on each side and take the bumper off as a hole piece, then put the shims in and reinstall.
  21. Nov 9, 2020 at 6:23 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    Alrighty will do
  22. Nov 9, 2020 at 4:00 PM
    RollTide82
    Michael
    2019 Tundra 4x4
    Couldn't get it lined up....started raining. Will try again tomorrow I guess...
  23. Feb 17, 2021 at 2:37 PM
    FitsofRage88
    Hill Country, Texas
    The stock bumper has a gap of 13-15mm from the body panels for a reason. I measured 3 trucks and measured from the body panel near front tires using a caliper; measurements are 13mm, 14mm and 15mm. The current ADD stealfighter design will leave a gap of about 6mm or less. So yes, it will rub as is and most people just live with it. The front and cabin are on body mounts so they flex. I modded mine and ended up getting 14mm. You can see the flex in the pix with OEM bumper. Pix was taken during my 37x12.5 test fit for nip and tuck on 3/1.5" lift.
