CB antenna hood mount
Discussion in 'Recovery & Gear' started by TheBeast, Jan 16, 2021.
  1. Jan 16, 2021 at 1:33 PM
    TheBeast [OP] The Beach
  2. Jan 16, 2021 at 2:28 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    grab this.
    TheBeast[OP] likes this.
  3. Jan 16, 2021 at 2:59 PM
    thanks !
    looks like cali raised has a similar product as well. I think that will work fine for my needs.
    GravityGear likes this.
  4. Jan 17, 2021 at 6:44 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I recently went through this exact same scenario and I found something very similar to this at Tractor Supply for only two bucks each. Hardware store/ Tractor Supply would be another place to try and look for a simple bracket like this.
    TheBeast[QUOTED][OP] likes this.
  5. Jan 17, 2021 at 7:12 PM
    @des2mtn any pics of your setup ? thanks
  6. Jan 17, 2021 at 7:26 PM
    des2mtn
    SW
    Tonto cover
    I will take a picture of the bracket and my mock setup in the morning. I haven't wired the lights yet so it isn't completely set up. The bracket I bought has four holes, but it can obviously be cut if you only need two or three holes. I'm looking to do two pods (amber/ white) on both sides, CB antenna on passenger side, and orange buggy flag on driver side.
    I do not have any experience with GMRS radios, but for my CB radio I originally put one of these on my ditch light brackets and put my antenna on it. https://www.amazon.com/gp/product/B000X3EQ3G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I was able to get a very low SWR reading and decent sounding transmission with it mounted on top of the ditch light bracket. I have since moved this mount and my antenna to my rear tail light and have since got poor reception - hence why I am doing this bracket solution to move it up front again with the addition of ditch lights.
  7. Jan 19, 2021 at 9:07 AM
    des2mtn
    SW
    Tonto cover
    @TheBeast Here is the Tractor Supply bracket I purchased and my mock setup so far. Antenna goes on the free hole or the hood bracket hole I'm thinking.
  8. Feb 7, 2021 at 2:16 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Damn 40 dollars for that little thing when a 15 inch gmrs antenna is like $10 and probably works better? Is it just because it’s tiny?
