CB Antenna Cable Routing
Discussion in '3rd Gen Tundras (2022+)' started by Kanadakid, Jan 25, 2024.
  1. Jan 25, 2024 at 8:05 AM
    Kanadakid
    Kanadakid [OP] New Member
    Donald
    2023 Tundra 1794
    Nothing yet
    Tundra Friends,
    Does the 3rd gen Tundra have a grommet somewhere under the undercarriage of the 3rd gen turn to route a co-ax antenna cable into the cabin ? The second gens do have this. If not where is a good place to run an antenna cable into the 3rd gen tundra cabin. Would prefer not to cut the weather stripping through the back door. Thanks for your thoughts and help....Kid
  2. Jan 25, 2024 at 8:21 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I had my back camera cable rerouted and I think there's a spot to run it outside under the back passenger seat... You willy have to pop open the plastic moldings under the passenger seat that hide the cables etc.
    Not sure if there are any other easier ways
    Kanadakid[OP] likes this.
  3. Jan 25, 2024 at 10:00 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    There's a drain plug/weather grommet almost directly under the driver's seat (plus a few more). You can route the cable through there.
    See the GMRS install post on my build thread to see if it helps: Duster's Double Cab - The Daily Do-It-All: GMRS Radio & Antenna Installation
    Kanadakid[QUOTED][OP] likes this.
  4. Jan 25, 2024 at 11:18 AM
    Kanadakid
    Donald
    2023 Tundra 1794
    Nothing yet
    Duster,
    wow this is perfect and very helpful. if I can ask how you ran your antenna cable into the cab after it when between the bed and cabin ? you very informative post sort of stops at that point. thanks again for a great post and help. Kid
    KroppDuster[QUOTED] likes this.
  5. Jan 25, 2024 at 11:29 AM
    KroppDuster
    Bilstein 5100s
    Since I've got a bed shell, the cable is pretty protected sitting between the cab and the shell. It runs down the back and I just used some cable clips to keep it from flapping around. I attached a few on the edge of the back window so I don't see the cable in my rearview mirror. Plus, if I need to remove them, they'll be easy to scrape off the glass.
