Cats Stolen. OEM or other to replace?
Discussion in '2nd Gen Tundras (2007-2013)' started by PNWtundrite, May 24, 2024.
  1. May 24, 2024 at 10:37 AM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Title says it all let me know your thoughts
  2. May 24, 2024 at 10:44 AM
    2mchfun
    Depends on insurance coverage and emissions requirements.
  3. May 24, 2024 at 10:49 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Sorry that happened to you! There are threads about this on the site. Most of the posts I've read noted that aftermarket cats had issues with codes once installed and some had to reinstall OEM cats once they became available. Definitely worth the research so the headache isn't prolonged.
  4. May 24, 2024 at 10:49 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Lots of good info here on the tundras.com site. I think there is a consensus that if you can go OEM you will have less trouble than aftermarket. some people have luck, some don't. I know they were backordered for OEM for quite a while, not sure if this is still the case.
  5. May 24, 2024 at 11:03 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    OEM, file a claim with your insurance and pay the deductible.
    NewImprovedRon likes this.
  6. May 24, 2024 at 11:10 AM
    2mchfun
    Check with your agent and if you can or if it makes sense, change to zero ded on comprehensive. In my case, it was only a few dollars different and worth every penny.
    Sean492 and 1lowlife[QUOTED] like this.
  7. May 24, 2024 at 1:14 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
  8. May 24, 2024 at 1:20 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Randy Morton and reywcms like this.
  9. May 24, 2024 at 1:39 PM
    Damn....I was just wondering the other day if cat theft was still happening.
  10. May 24, 2024 at 1:59 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    ^ yes cat shields are something to consider.
    I'd look into @Talon2006 if I was buying today.
    He is a forum vendor..
    Welcome to Talons Garage! | Toyota Tundra Forum (tundras.com)
    Toyota Tundra – Talons Garage
    Talon2006 likes this.
  11. May 24, 2024 at 2:07 PM
    2mchfun
    Not just cats anymore! Due to inflation and cat shields, now they take the whole vehicle!
    whodatschrome and 1lowlife like this.
  12. May 24, 2024 at 2:44 PM
    I did see car theft is on the rise.
    2mchfun[QUOTED] likes this.
  13. May 30, 2024 at 9:20 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
  14. May 30, 2024 at 11:31 AM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    Depending on where you're located, OEM may be required. In CA, we aren't allowed to install after-market cats so it has to be OEM. If you install anything other than OEM, the smog shops will fail you. Companies won't even ship non OEM cats to CA addresses.
  15. Jun 5, 2024 at 3:17 PM
    texmln
    texmln New Member
    Back in 2020 the driver side cat failed on my 2008 at 180k. I put on a Walker replacement, which at the time cost $317 vs the $2700 Toyota wanted. The Walker bolted up perfectly (make sure you use new gasket rings) and I had the truck another three years and put 40k miles on it with no problems at all and no codes. People kept telling me an aftermarket cat would last two years at best but at that price differential I could have replaced the driver side 8 more times and still break even (taking 16 years minimum if the two year thing held true). Go with a reputable aftermarket brand.
