Catalytic Converter
Discussion in '1st Gen Tundras (2000-2006)' started by Whothefat, Jun 19, 2020.
  1. Jun 19, 2020 at 5:01 PM
    Whothefat
    Whothefat [OP] New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Hey guys,
    Someone stole one of the catalytic converters off a friend of mine's Sequoia a couple days ago... has anyone replaced just one of these? Or is it better to replace both of them at the same time?
    Any quality replacements for a decent cost?
    His truck sounds badass straight piped though!
  2. Jun 19, 2020 at 6:06 PM
    Professional Hand Model
    Hand Protectors
    Try Walker only because I remember someone else saying this. Brand new OEM are like $1500 each. Might want to file insurance.
  3. Jun 19, 2020 at 7:53 PM
    Whothefat
    Clark
    Las Vegas
    Thanks for the tip. $200 on rock auto isn’t too bad. Hard to justify $1500 for one side on a 18 year old truck!
  4. Jun 19, 2020 at 8:19 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I have used Walkers on a couple on a couple of vehicles and they worked just fine.
  5. Jun 20, 2020 at 7:16 AM
    Hand Protectors
    Well, if insurance is paying they need to pay for OEM at $1500ish PLUS labor. Your deductible? Doing the math you might have something positive to consider.
  6. Jun 20, 2020 at 7:55 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Just had mine stolen recently. Apparently on 05 there is no aftermarket replacement. Had to use OEM. $2100! Just for the converter 1B584D83-112F-4DE6-9910-4C5B4FDD072C.jpg757BD32C-2D92-49AA-A163-D7ECD3F733C4.jpg E7559394-7919-419C-B836-477F5EC1596D.jpg
    And the POS damaged the O2 sensor pigtail also! :mad:
  7. Jun 20, 2020 at 8:10 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I went magnaflow replacements and they both worked great. No codes. About 250 each for direct bolt on replacements
    hammeron, N84434 and YardBird like this.
  8. Jun 20, 2020 at 8:30 AM
    Hand Protectors
    BestGen pics of his 05 leads me to believe the 06 @ whothefat my be in the same boat. I wonder if insurance covers this?
    BestGen likes this.
  9. Jun 20, 2020 at 9:04 AM
    BestGen
    BestGen New Member
    Paul
    My insurance covered it thankfully. Still I was out of pocket $300. Total bill was $2644.25!
    01tunder, 831Tun, chugs and 1 other person like this.
  10. Jun 23, 2020 at 4:22 AM
    Hand Protectors
    Whats the ‘skinny’ (update) on this repair?
  11. Jun 24, 2020 at 12:11 PM
    Whothefat
    Clark
    Las Vegas
    We ordered the Walker from RockAuto so we're waiting on delivery. Looks to be a bolt on replacement. $250 with shipping.
    Ill grab some pictures and post them up when we do the job this week
  12. Jul 6, 2020 at 11:38 PM
    jwarren2
    jwarren2 New Member
    James
    Sugar Land Texas
    2014 Black Tundra Platinum 4x4
    None yet but making a list and looking at the budget.....
    This type of theft is going on rampant here in Houston. Here is what you need to prevent this from happening again.
    Mike59, Rex Kramer, bmf4069 and 4 others like this.
  13. Jul 7, 2020 at 6:36 AM
    jamess28
    jamess28 New Member
    Tulsa, OK
    2005 DC SR5 TRD Off-road 4x4
  14. Jul 7, 2020 at 8:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    OR Fab used to make one for first gens.i haven't seen another with that design.
    Best bet is to check in with Skid Row, they make plates for our trucks but I'm not sure how well they protect the cats. Maybe somebody with the full kit can chime in.
    Whothefat[OP] likes this.
  15. Jul 8, 2020 at 11:51 AM
    Whothefat
    Clark
    Las Vegas
    Got this job knocked out yesterday. It is not too rough of a job, a couple YouTube videos out there show all the details. I did round off the head on one of the bolts connecting the cat to the header, had to cut it off with a Dremel there isn’t much room in there.
    You can get access to the bolts there if you take off the front tire and pull down the little rubber trim piece.
    This was on a really clean ‘03 and those bolts really didn’t want to break free!
    thanks for the tips everyone!
  16. Jul 8, 2020 at 11:52 AM
    Whothefat
    Clark
    Las Vegas
    I park in a garage at night but I wouldn’t mind having one of these!
    FlyingWolfe likes this.
  17. Jul 14, 2020 at 4:31 PM
    Whothefat
    Clark
    Las Vegas
    Update: My buddy with the Sequoia told me today he was driving after we replaced the CAT and got the Check Engine Light, VSC TRAC and VSC OFF lights on. Coming by later to run the codes, anyone have this issue?
  18. Jul 14, 2020 at 4:59 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Likely one of the ABS sensors.
  19. Jul 14, 2020 at 5:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If the sensor wasn't plugged in or seated correctly it may trigger it as it goes through 2 cycles before popping the CEl, If the sensor was replaced while the battery was still connected it will trigger a CEL as well. Double check connectors and if all is good it should clear it self in 2 or 3 cycles, or clear it out with an obd2 reader and it should be fine after.
    Darkness likes this.
  20. Jul 14, 2020 at 5:43 PM
    Trying to avoid going to the garage to slide under the truck, do those cat-cover plates prevent any specific regular maintenance, or is it pretty much a bolt-up-and-forget?
  21. Jul 14, 2020 at 5:48 PM
    blackdemon_tt
    Based on these pictures, it appears for 2wd its a bolt on and forget, 4wd it appears it will need to be removed for maintenance.
    Eventually both will have to be removed for maintenance, for example that starter...
  22. Jul 14, 2020 at 8:28 PM
    Whothefat
    Clark
    Las Vegas
    that must have been it, we unplugged the O2 sensor with the battery still hooked up. Thanks for the reply!
  23. Jul 15, 2020 at 4:45 AM
    Hand Protectors
    I just did all 4 of my o2 Sensors with the battery still hooked up. No check engine light after doing the work. Also, I Ohms tested both my Old Rear Sensors and they were zero (should be 13ish) and never set off my CEL for who knows how long?
    So either the battery hook/unhook (setting off code) is true or something is wrong with my Computer. My CEL lights up at Ignition start per the normal process and disappears as it should with the other lights. :help::rofl:
  24. Jul 15, 2020 at 9:45 AM
    Youngfrankenstein
    Youngfrankenstein New Member
    2015 4x4 CM SR5
    Man, that SUCKS! I am hoping your friend lives in Las Vegas also, and not California.
  25. Jul 15, 2020 at 9:57 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    They just made a huge bust here in Edmonton, found a storage locker with about $300,000 worth of catalytic converters.
    My wife's was stolen off her Mazda CX-5 a little while back, they took off the O2 sensor and the second converter. Since the second one was after the O2 sensor i just had a shop weld in a straight pipe and install a new O2 sensor, worked fine as there was no more sensors after the O2 one.
  26. Jul 15, 2020 at 10:13 AM
    Youngfrankenstein
    2015 4x4 CM SR5
    That is terrible. The $$$$ & crappy days victims dealt with because by these morons. I hope they get some serious time behind bars.
  27. Jul 15, 2020 at 10:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This must be a west coast thing. I never hear about cats getting stolen here in TN. I'm sure it's happened but you seem to have an abundance of shitheads living out there.
  28. Jul 15, 2020 at 10:31 AM
    Youngfrankenstein
    2015 4x4 CM SR5
    Could be the very strict/expensive CA converter replacement laws that drive the black market. Toyota Prius cars have a serious cat theft problem, I believe.
  29. Jul 15, 2020 at 10:50 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Our starters are up in the valley.
  30. Jul 15, 2020 at 11:11 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is no hole for trans fluid changes, so not a permanent bolt on. Unless you make a hole or get a valve to replace the drain plug.
    shifty`[QUOTED] likes this.
