Cat protection on the cheap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blue By U, May 13, 2022.
  1. May 13, 2022 at 8:37 PM
    Blue By U
    Blue By U [OP] New Member
  2. May 13, 2022 at 8:47 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    That will add about 30 seconds to the 3 minute process. Better than nothing but not by much.
    Rocko9999, 1794TX and 1lowlife like this.
  3. May 13, 2022 at 9:38 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    In the video I noticed they used wire ties in some spots. Not quite what I would consider a real deterrent. That perforated is real easy to cut. It cuts like butter or a person could just hook a chain to it and pull, causing even more damage.
    Rocko9999 likes this.
  4. May 13, 2022 at 10:02 PM
    Blue By U
    That stuff is hard to cut with tin snips that I doubt these scum bags carry around. This game they are playing is about smash and grab. If they looked under a vehicle like that, what do you think they would say? The mounting could be more thought out for sure. But the material and idea is not bad.
    HulkSmurf14 likes this.
  5. May 13, 2022 at 11:00 PM
    Booney
    Booney New Member
    I don't recall anyone posting where their cat was cut off with tin snips. They usually use a sawzall or maybe a cordless grinder but no tin snips that I can recall. I have worked with expanded steel like that. It's pretty easy to cut.
  6. May 13, 2022 at 11:13 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It’s definitely an option worth considering if you are on a tight budget. Personally I would not want it on my rig, cause I think it looks trashy. But if it’s gonna save your cats from a thief, suddenly it’s looking pretty good.
  7. May 14, 2022 at 6:56 AM
    Mr Badwrench
    Mr Badwrench New Member
    I am going to rig my truck so it just explodes if the cats are tampered with. My insurance deductible is pretty cheap. :monocle:
    No. No, I probably won't do this.
  8. May 14, 2022 at 7:34 AM
    Self tapping screws is not a solution. Now if the expanded flat was tack welded in place it might prevent a theft. I have even heard these thieves are now carrying several different security bolt bits and getting away with the skid plates and selling them as well. Go figure.
  9. May 14, 2022 at 7:43 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Wow that would suck.
    The socket for the pentagon security bolts that Valhalla sells can be found on Amazon.:eek2:
    I bought a spare socket...:D
  10. May 14, 2022 at 7:44 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    When my daughter's cats were stolen, there was no saws all used, only a socket, they merely unbolt the units, no cutting, that makes too much noise.
    OP - hope that idea works as some kind of deterrent, maybe they'll move onto the next 'normal' one. If going that route, I'd be tempted to use a hog panel.
  11. May 14, 2022 at 8:14 AM
    Yep. It's kind of like home invaders buying bump keys online. You can get a bag of them for 10.00. That is what two guys were using in attempting to get into my house. They had already unlocked the handle lock and was working on the deadbolt when they noticed the homeowner pointing a rifle at center of mass.
    Even more shocking was the 100+ lb German Shepherd that wanted to tear their heads off on the other side of the door didn't even phase them.
  12. May 14, 2022 at 8:39 AM
    Booney
    Booney New Member
    Criminals aren't known for their intellect. Glad you were able to react. It might have saved your life, and theirs.
  13. May 14, 2022 at 11:05 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I do like how you leave the option open. :laugh:
    Mr Badwrench[QUOTED] likes this.
  14. May 14, 2022 at 11:26 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    That isn’t going to stop thrives at all . They will rip that off and be gone real quick. Got to think of something else Better
  15. May 18, 2022 at 8:17 PM
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    Just posted in the sell section if anyone needs some
