Cat extended life coolant in Tundra, thoughts?
Discussion in 'Performance and Tuning' started by josh04, Feb 25, 2024.
  1. Feb 25, 2024 at 5:58 AM
    josh04
    josh04 [OP] New Member
    Josh
    Brunswick GA
    2004 Black Tundra SR5, 1993 White Chevrolet S10
    K&N Cold air intake
    Hello all, I am doing the timing belt/water pump on my 4.7 and can easily get my hands on CAT ELC (the red stuff). I am currently running Peak Asian vehicle coolant, but with a good flush would anyone know if it would be OK to run ELC in my engine? If anyone else is running an ELC I’d like to hear your experience. Thanks,
    Josh
  2. Feb 25, 2024 at 7:07 AM
    2mchfun
    Don't sweat over $40, and just cuz you can, doesn't necessarily mean you should..... okay? Good!
  3. Feb 25, 2024 at 8:32 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    The Toyota coolant is an ELC, I would compare the composition of the CAT to the 'yota before using it.
  4. Feb 25, 2024 at 8:59 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    CAT is a nitrated OAT coolant. I would use the Asian Pink/Red instead. This is from a NC dealer site.
    Toyota Pink Super Long Life Coolant.
    When it comes to the Toyota pink coolant, there are different ingredients such as:
    • Water (7732-18-5)
    • Ethylene Glycol (107-21-1)
    • Diethylene Glycol (111-20-6)
    • Sebacic Acid (111-20-6)
    • Potassium Hydroxide (1310-58-3)
    Toyota Red Coolant Long Life.
    Toyota red coolant is one the best car coolants to put into your Toyota. Here’s what is in the Toyota red coolant.
    • Diethylene Glycol (111-46-6)
    • Water (7732-18-5)
    • Organic Acid Salt (532-32-1)
    • Hydrated Inorganic Salt (1310-58-3)
  5. Feb 25, 2024 at 10:07 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    OE. one of the few items I've been told/read to keep Toyota brand.
  6. Feb 25, 2024 at 10:56 AM
    josh04
    Josh
    Brunswick GA
    K&N Cold air intake
    Not sweating, it’s tax season and pretty cold outside :thumbsup:
