Cat delete CEL issues/ AFR ratio
Discussion in 'General Tundra Discussion' started by Youalreadyknow, Jan 22, 2025.
  1. Jan 22, 2025 at 11:22 AM
    Youalreadyknow
    Youalreadyknow [OP] New Member
    Kohen
    08 black tundra sr5
    I had to get my front cats removed due to the front drivers side cat being in pieces on the inside and after doing this, I’ve had a check engine, light and terrible gas mileage. Is there anything I can do to remove the check engine light and have the right air fuel ratio? I’ve seen people say on the O2 sensors, but I was wondering if that just remove the check engine light and still has a bad air fuel ratio or if that fixes the air fuel ratio.
  2. Jan 22, 2025 at 11:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Replace the cats
    Black@Blue19 and The Black Mamba like this.
  3. Jan 22, 2025 at 12:05 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You will need the front cats or a tune modified accordingly. The only cats you can remove without issue is are the rears as those are after the 02 sensors
  4. Jan 22, 2025 at 1:01 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Did you cut the cat short of the rear heated 02, as in the rear O2 is still reading inside the exhaust? If so, you can get an 02 sensor fouler / spacer to raise the sensor out of the exhaust and that may settle down the ECM. Ultimately, you'll need to replace the cats.
  5. Jan 22, 2025 at 2:52 PM
    The O2 sensors are the air/fuel ratio sensors.
