RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Nov 24, 2021 at 1:01 PM
    #481
    RainMan_PNW
    RainMan_PNW [OP] SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Interesting idea.
    I’ll have to do some looking and see what I can come up with.
  2. Nov 25, 2021 at 8:09 AM
    #482
    ToyoD
    ToyoD New Member
    Drew
    2021 SR5 DC
    Build page link in signature
    Thank you!
    PS Happy Thanksgiving!
  3. Nov 25, 2021 at 1:04 PM
    #483
    RainMan_PNW
    Casey
    Clark County, WA
    Looking at the Parking Assist diagram (for 2018-2021), all of the sensors feed into an ECU that handles the actual sensor data. The front sensors are daisy-chained (one connects to the other, then that one to the ECU) and the rears are also daisy-chained to the ECU. From that ECU, the signals are sent to the instrument cluster as individual inputs.
    You can see circled the inputs for the FR, FL, and the buzzer (which is not differentiated between any specific sensor). Since the buzzer is a single common signal, I wouldn’t use it for this.
    Now, the way that I understand the ABC switch and relay to work is that when the switch is in the “neutral” position, everything is connected to the HU per original function. The Reverse wire triggers power to the camera and switches the head unit over to camera view. Flipping the switch to either position hijacks the reverse wire circuit and sends a faked “reverse” signal to the HU to switch it to camera view (and power the rear camera). When the the switch position is in “rear” mode, it does not send a signal to the camera switching relay (which is a double-throw, single pole relay that is “normally closed” to the rear camera position). If the switch is positioned to the front camera, then the switch sends power out to the front camera and power to the switching relay to switch it over to send the front camera signal to the HU.
    So, in order to try to do what you are describing - specifically when either FRONT sensor activates, have the front camera automatically switch on and display on the HU - you would need to grab the signal from either front sensor and use that to power a relay that will then send a reverse signal to the HU, power on the front camera, and switch the signal over to the front camera. It is very possible you could do this using some diodes to run both front sensor signals to the coil on a SPDT relay that had the green wire from the ABC switch run to the “NC” switch and and a separate power source running to the “NO” switch. The diodes would prevent the signal from one sensor to be pushed “backwards” to the other - they do result in a voltage drop, but probably not enough to affect the operation of the relay coil (would need to do some testing). The output power from that relay switch would then pass along the green wire to the ABC switching relay the way it currently does now (with the splice that actually powers the camera being down “stream” of the relay).
    I’m not 100% certain on this, however, without having a better diagram of the internal functions of the ABC switch to understand exactly how it is sending the reverse signal to the HU when in “front” mode. But in theory I think it might work.
  4. Nov 25, 2021 at 4:17 PM
    #484
    ToyoD
    ToyoD New Member
    Drew
    2021 SR5 DC
    Wow thank you. That was a whole lot more of a response than I expected! I kind of feel like that part in Dumb and Dumber where he says “So you’re saying there’s a chance!?” Lol
    No but I really appreciate this and I think I followed what you’re saying. I plan on ordering the kit with their Black Friday sale and may attempt this in parallel with you if it’s something you’re interested in too maybe we can go back and forth to figure it out?
    I also wanted to ask;
    Now that you’ve had this Front/Rear system for a while;
    1. Are you happy with it?
    2. Anything you think is a major downfall to the system?
    3. Do you mind sharing why you chose this kit over the other(s) out there?
  5. Nov 25, 2021 at 7:34 PM
    #485
    RainMan_PNW
    Casey
    Clark County, WA
    So, the TRD Pro doesn’t have parking sonar, so no interest in me trying it out, but more than happy to provide thoughts and ideas to someone else. I’ve never had a vehicle with parking sonar, but always wanted a front camera and just never got around to figuring it out in my 2008 (that and the little pop-down video screen was like 2.5” square). I did add BSM/RCTA to my truck, but that was a relatively simple task compared to the sonar system because of the components needed (including an ECU).
    For me, the front and rear cameras give me better clarity of what I’m close to than parking sonar would - I can SEE what is there and have figured out how to gage the distance. So in that regard, yes, I am very happy with it.
    Room for improvement? The fidelity of the front camera is more grainy than the stock rear one. It works fine, but certainly not high def. It might be possible to find a better one, but horizontal mounting that I am using and the rigid bolt-through mount seems to be a crapshoot to find a good quality camera. At the end of the day, it does very well.
    I also don’t really care for the fact the blue light in the switch isn’t a match to the rest of the switches in the truck. But that’s really minor, and mounting it where I did (behind the shifter), it isn’t a switch I ever actually look at. I find it by feel instead.
    Why I picked the ABC setup? Mostly the switch. I think the FRAC harness is just as “plug and play” as the ABC harness, though not entirely sure (I found the ABC one first). But I wanted a switch that fit the factory switch openings and looked more OEM than the round rocker switches.
    TaquitoBandito and ToyoD[QUOTED] like this.
  6. Nov 25, 2021 at 7:48 PM
    #486
    ToyoD
    ToyoD New Member
    Drew
    2021 SR5 DC
    Well thank you for all the help especially since you can’t even use the idea. I didn’t realize they didn’t come on the TRD Pros.
    And thank you for the feedback on your system and personal opinion on it. I’ll see what I can do once my kit arrives and I get it installed. I’ll keep you posted so you have an idea on how close your theory is on this.
    RainMan_PNW[OP] likes this.
  7. Nov 25, 2021 at 8:30 PM
    #487
    RainMan_PNW
    Casey
    Clark County, WA
    Sure thing. Let me know if you need any more ideas on it. Like I said, the one thing I’m not entirely sure about is how the ABC switch sends the reverse signal to the HU when in front camera mode. I SUSPECT that they are sending the signal out via the orange wire from the switch, which is what powers the orange LED indicating the camera is on (and with the front camera is on, BOTH LEDs are lit). That would all be internal to how the switch itself is wired.
    ToyoD[QUOTED] likes this.
  8. Nov 25, 2021 at 9:19 PM
    #488
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    What’re your thoughts on the Val cat plates and the trd plate? I’m hemming and hawing about whether to pick up the third plate and just sell the trd to make install easier. Or do you think with the new bracket it’ll be that much easier. Figured I’d ask the install master..
  9. Nov 26, 2021 at 9:56 AM
    #489
    RainMan_PNW
    Casey
    Clark County, WA
    I haven’t really followed the Val thread since I installed my plates - not sure what the “new bracket” is. The install really wasn’t difficult (other than laying on my back in the gravel without a helper) and it’s been one of those things that once I installed them, I’ve pretty much forgotten about them (until it’s time to service the transfer case, I’m sure).
    dittothat[QUOTED] likes this.
  10. Nov 27, 2021 at 9:22 PM
    #490
    dittothat
    Nick
    SD
    2016 MGM Platinum
    Thanks. Copied you; went with 2
  11. Jan 4, 2022 at 4:24 PM
    #491
    RainMan_PNW
    Casey
    Clark County, WA
    Been driving a lot (now past 27,000 miles), but not much on the build front lately. I’ve got a few small things at the house to swap out, but it’s been too cold/snowy lately to do much.
    Here’s a recent shot up at Timberline of some dingleberries hitching a ride on my steps from the icy snow on the drive up.
    Also started getting a few patches worked into the headliner
  12. Jan 7, 2022 at 10:05 AM
    #492
    RainMan_PNW
    Casey
    Clark County, WA
    Updated my radio to head unit software version 1060 and navigation software version 1110 today.
    Went to this website:
    https://www.toyota.com/firmware-updates
    Entered my info as a 2020 Tundra with Navigation and it showed two updates were available.
    Downloaded the files, stuck them on a thumb drive (2GB or larger, formatted to FAT32), then followed these instructions (since I couldn't find instructions on the site):
    1. Unplug anything from the USB port (normally my CPLAY2AIR adapter is in there).
    2. Turn ON the truck engine
    3. Plug in the USB drive, wait until the head unit says "reading USB drive"
    4. Go to Settings -> General -> Software Update
    5. It will pop up "Software update found" and prompt you to install it. Follow the steps on screen.
    6. When the update is done (it took ~5 minutes), shut OFF the truck.
    7. Unplug the USB, then turn ON the engine again.
    8. Navigate back to the software update screen again and confirm the new software numbers.
    Here's the information after the update.
    Change Log info from the above site shows:
  13. Jan 7, 2022 at 10:22 AM
    #493
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    curious to know as well. Seems weird that all the other switches light up except for this one.
  14. Jan 7, 2022 at 10:37 AM
    #494
    1794TX
    Steven
    N.TX
    '20 1794
    Thank you sir. Updating now.
  15. Jan 7, 2022 at 10:40 AM
    #495
    RainMan_PNW
    Casey
    Clark County, WA
    That particular switch is from a specific trim of the 2013 Toyota Auris (European version of a Corolla I think). Finding one with blue backlighting (most are green backlight) is difficult. But while the shape and outward appearance of the switch is the same as the non-illuminated one in the Tundra, it is a completely different animal inside. It is essentially a full ECU inside and so as I was testing it I couldn't get it to consistently control the mirror adjustment function. It would simply "bump" slightly and then stop and not work again.
  16. Jan 7, 2022 at 11:14 AM
    #496
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    alright, thanks for the details. With a 1794, and following your quest for auto-power folding mirrors and the differences in trim, I knew you would know.
  17. Jan 7, 2022 at 11:24 AM
    #497
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Any notable changes?
  18. Jan 7, 2022 at 11:52 AM
    #498
    RainMan_PNW
    Casey
    Clark County, WA
    According to the change log:
    I haven't actually driven or tested it. Can't say that I ever had any of these issues anyway.
  19. Jan 13, 2022 at 9:24 AM
    #499
    RainMan_PNW
    Casey
    Clark County, WA
    Picked up the ME-SO Customs map lights and rear dome light when they finally released last Friday, and got them installed last night.
    Map Lights
    Dome Light
    The installation was pretty simple and straight forward - there is a video on each of the linked product pages that shows the process. I didn’t need to (or bother) removing the rear dome light from the head liner, it was easy to do there in the truck. On the map lights, you could also leave the overhead console in the truck to do the swap - I chose to remove it because I wanted to see how the rest of the overhead console was assembled for other / future ideas. Do note that the map light reflectors cannot be removed without bending them, so there’s not really any way to “go back” once switch those (without replacing the overhead console).
    Here’s picks in RED mode (both map lights and both rear dome lights are on in these pictures)
    And here is pictures in WHITE mode (again, all lights are on)
    The white is pretty bright - definitely lights up the interior and makes it easy to see things. It is definitely more expensive than the FyreFly’s bulbs I had installed, but also much more functional. I’m happy.
  20. Jan 14, 2022 at 3:52 AM
    #500
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    These are very nice Casey, I have the same bulbs you had. I assume these do not interfere with the key fob. I maybe replacing mine also. So a really big difference in the lighting? By the pics it looks like it.
  21. Jan 14, 2022 at 5:33 AM
    #501
    WawaLunar
    WawaLunar New Member
    2021 TRD Pro Lunar Rock
    I was wondering the same thing about the key fob interference but based on everyone's praise about these in Taco's, assume they don't and went ahead and bought a set.
  22. Jan 14, 2022 at 5:53 AM
    #502
    RusPro21
    Don
    Pa.
    Yeah I will wait to here Casey’s comments on the key fob before I purchase them. Install looks easy. I like to have a lot of light inside.
    WawaLunar likes this.
  23. Jan 14, 2022 at 5:56 AM
    #503
    :101010:
  24. Jan 14, 2022 at 7:42 AM
    #504
    RainMan_PNW
    Casey
    Clark County, WA
    I have not noticed any key fob interference or issues. I pretty much never actually pull my fob out of my pocket - I use the handle lock and unlock pretty much always, and it has been no different since installing these.
    And yes, in white light mode, there is a significant amount of light.
    WawaLunar and RusPro21 like this.
  25. Jan 14, 2022 at 7:45 AM
    #505
    RusPro21
    Don
    Pa.
    You sold me dude!! Are you using the red for any cituation?
  26. Jan 14, 2022 at 7:48 AM
    #506
    RainMan_PNW
    Casey
    Clark County, WA
    I've only had them in for 36 hours!
    I have the rear ones set to red and the fronts set to white for when I unlock/open the doors. Seems to be a good balance of not being too bright when I open the truck to throw my pack in the back seat.
    RusPro21[QUOTED] likes this.
  27. Jan 14, 2022 at 7:50 AM
    #507
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    I got the same lights. Damn they are bright!! How does your driver map light fit? Mine is a little loose.
  28. Jan 14, 2022 at 7:58 AM
    #508
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Is the fob antenna somewhere different on 20-21? I know in 18-19 they moved it to the 3rd brake light housing so you need to be careful on what make/model of LEDs get thrown in the cargo light sockets, but didn't think the interior lights had any effect.
  29. Jan 14, 2022 at 8:27 PM
    #509
    RainMan_PNW
    Casey
    Clark County, WA
    Mine doesn’t seem to fit any different than the stock lens cover did
    bulldog93 likes this.
  30. Jan 14, 2022 at 8:28 PM
    #510
    RainMan_PNW
    Casey
    Clark County, WA
    No, I’m pretty sure it’s in the same spot and the cargo lights are the biggest culprit of issues.
    gosolo and TRDFerguson[QUOTED] like this.
