Carrier Bearing - Play Allowance
Discussion in '1st Gen Tundras (2000-2006)' started by Bourbon, Dec 7, 2024.
  1. Dec 7, 2024 at 10:44 AM
    Bourbon
    Bourbon [OP] 2006 Tundra DC V8 4WD
    2006 Tundra TRD DC
    Hey all, trying to find out how much play is acceptable in the carrier bearing assembly. I just started noticing intermittent vibration when you coast after hitting 55-60 mph. There is no vibration any other time. I regularly grease the driveline when I change oil, all the u-joints seem fine.
    To me the carrier bearing seems like it has too much play. I was trying to reference the video in this previous thread, but doesn't look like it's available any longer: https://www.tundras.com/threads/center-carrier-bearing-play.45911/
    I took my own video but it doesn't seem I can upload it - it is a .mp4 video (I don't have a YT account)? Any help is appreciated, thanks.
  2. Dec 7, 2024 at 11:09 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Sorry if I come off as short or curt, but I'm working in the garage and noticed your post.
    If you have over 150k on the truck and do not know the service history of the driveline, I would say it's very likely it's time to replace the carrier. The fact that you're *here* and mentioning vibes clearly shows there's an issue. Don't be surprised if a driveline shop also recommends u-joints.
    Edit: my point being that you intuitively already understand something isn't quite right, and you're probably correct. No need for a spec. You're already getting symptoms/signs it's out of spec.
    The Black Mamba likes this.
  3. Dec 7, 2024 at 11:23 AM
    Bourbon
    2006 Tundra TRD DC
    It's a 2006 and I am at 120k miles, I'm the second owner but I have the full service history as far as I know. Driveline is original I believe.
    I don't have any issues with doing the maintenance, I've done u-joints before but I've never had a truck with a carrier bearing like this.
    So in short I fully expect to replace the driveline components, even preventatively if they are not the culprit. But I would like to learn more about this component because several posts say that with the rubber carrier, play is expected.
    Appreciate your thoughts here!
  4. Dec 7, 2024 at 11:27 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    If you can wiggle the driveline up and down more than 1/4" inside the carrier bearing i would say its about time for a new one
    If you can wiggle the driveline up and down more than 1/2" inside the carrier bearing i would say its definitely past time for a new one
  5. Dec 7, 2024 at 11:35 AM
    Desert Dog
    I get it. I'm into the preventative aspect as well. If it were me, I would replace the u-joints and the carrier at this point, but that's me. Just remember, the driveline is a system. It is possible there are other worn components in the system that are contributing to your symptoms (e.g. worn mounts). Hard to say. You're just in a situation where you have to bite the bullet.
  6. Dec 7, 2024 at 11:40 AM
    Desert Dog
    You have to keep in mind that the components are currently under load, or tension, and once released, may exhibit more play than when connected. An experienced driveline shop will understand this.
    Also, lack of cracking on the seal does not necessarily mean the bearing is still good and in spec.
  7. Dec 7, 2024 at 11:41 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Not a difficult job but be sure to mark the driveshaft sections with a paint pen to properly clock the driveshaft and preserve the balance on reassembly. The CB and u-joints are Dana Spicer from the factory so buy those not Toyota as they are the identical part and significantly less expensive.
  8. Dec 7, 2024 at 5:17 PM
    shifty` I'm having daydreams about night things
    I probably have a solid 1/2" - 3/4" of play in my carrier. My 2006 Tundra has 80k salt-free, well-maintained miles as of last month.
    My carrier bearing is perfectly fine and healthy.
    It's my observation the carrier bearings on these trucks intentionally have a fairly wide amount of movement in them and I disagree with your assessment.
    Radix, Weagle and ATBAV8 like this.
  9. Dec 8, 2024 at 5:33 AM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    It would be highly unusual for these to have been balanced as an assembly from the factory.
  10. Dec 8, 2024 at 6:28 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Really? Please explain.
    FrenchToasty likes this.
  11. Dec 8, 2024 at 7:40 AM
    You don't mark your driveshafts so you can easily re-clock them as they were when reassembling? What's the logic there?
    PNW15 and ATBAV8 like this.
  12. Dec 8, 2024 at 7:49 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    U joints being in phase is a real thing?
    shifty`[QUOTED] likes this.
  13. Dec 8, 2024 at 7:56 AM
    Are you being serious or facetious?
    I love answering questions with questions?
  14. Dec 8, 2024 at 8:06 AM
    FrenchToasty
    Mo
    Bone stock
    I thought you knew me better?
  15. Dec 8, 2024 at 8:41 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    This is a pretty subjective as well - being that the driveshaft is a hefty unit and getting under the truck and pushing it up/down has the capacity to yield a hell of a range given different folks with different strokes.
    OP - as any other vibration thread goes, there are lots of considerations and so many posts on this topic. It could be as simple as some mud/road debris that has caked itself onto the inner wheel throwing one (or more) wheels off balance to a poor observance from the poster who later realizes they were driving a a shitty stretch of road during their normal route (intermittent in nature) and decided to post up the problem on here.
    That being said, 120k and trucks age aren't out of question for carrier replacement (mine was done around 170k).
  16. Dec 8, 2024 at 12:40 PM
    Bourbon
    2006 Tundra TRD DC
    Here is the video of my carrier bearing. Again, I'm at 120k, original driveline, and I get slight vibrations when the driveline is unloading (letting off the accelerator at highway speeds). I think this could be my issue but I am not certain.
    Desert Dog likes this.
  17. Dec 8, 2024 at 12:53 PM
    Desert Dog
    You just answered your own question. Definitely time for carrier replacement. Again, I would do u-joints as well because it functions as a system. IOW, any worn components will wear out new components quicker.
    Keep us posted, please.
  18. Dec 8, 2024 at 12:55 PM
    Bourbon
    2006 Tundra TRD DC
    Perfect, good to know. I called my local NAPA, they have a machine shop and will balance the driveshaft when I bring it to them. This truck is not my daily driver so I can pull the shaft and do it myself. Thank you!
    Desert Dog[QUOTED] likes this.
  19. Dec 8, 2024 at 12:57 PM
    Desert Dog
    Absolutely. I was going to edit and suggest a balance of the shaft. You're on the right track.
  20. Dec 8, 2024 at 2:35 PM
    Mine definitely doesn't CLUNK CLUNK like that when dropping it.
  21. Dec 9, 2024 at 1:50 AM
    gagecalman
    gagecalman New Member
    Maryland
    2006 Tundra DC SR5 4WD 4.7 V8
    shifty` likes this.
  22. Dec 10, 2024 at 12:39 PM
    Bourbon
    2006 Tundra TRD DC
  23. Dec 10, 2024 at 12:59 PM
    Desert Dog
    You're fine, you got the correct one for your application.
  24. Dec 10, 2024 at 2:14 PM
    bfunke
    South Carolina
    They are the same - both 1.81” ID bearings.
  25. Dec 10, 2024 at 2:51 PM
    gagecalman
    Maryland
    Not really the correct one for your 4X4.
    There are 2 bearings that fit and both will work but the one for the 4X4 has seals on both sides and the other one does not have seals.
    Your original will probably be marked Toyota 37235-35030. Dana Spicer 5002007 is the correct part with seals on both sides. It's actually marked 37235-35030.
    On Dana's site 2117501X looks like 5002334 with no seals. It's for the 2WD.
    KNABORES and shifty` like this.
  26. Dec 10, 2024 at 2:58 PM
    Then you really should've verified ahead of time. People have been thru it here and know from experience. There's a thread on it.
  27. Dec 10, 2024 at 3:32 PM
    hpark21
    hpark21 New Member
    06 Black Tundra TRD Access cab 2WD 4.7L
    Mine had a weight stuck to one of the parts and had a sticker saying that they are balanced from factory.
    I replaced u-joint 2 weeks ago and at the same time checked my carrier bearing and it was smooth and had practically no play when I spun it when the drive shaft was off the truck so I was surprised that when people said having play is normal.
    When you install it, don't forget the side with 1 hole is the bottom (towards the ground).
  28. Dec 10, 2024 at 5:23 PM
    Bourbon
    2006 Tundra TRD DC
    Darn, I hope that's not the case, I specifically chose the one for 4WD. re's a picture of the one I chose from the selection I have.
    I'll call Rock Auto tomorrow.
  29. Dec 10, 2024 at 5:35 PM
    If you find a way to reach RockAuto by phone, let us know. I spent 30 minutes trying to find a way to talk to a human and came up short. Had to email and wait for a reply. There surely has to be a better way. Their support is f’n awesome when you get someone. Just with it was easier to get someone!
  30. Dec 10, 2024 at 10:46 PM
    Desert Dog
    OK, Bourbon, I don't mean to clutter your thread, but I may have learned something today, and perhaps you have, too.
    I saw exactly what Bourbon saw from RA re: the carrier bearing application, and from numerous other reputable outlets as well, including Summit Racing. So, in light of this, does this mean that, technically, the 2WD version will fit and function on the 4WD version of our trucks? If so, it logically follows that the 4WD version will technically fit and function on a 2WD truck. Am I missing something?
    dbittle likes this.
