Carrier bearing help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Flyinhigh90, Oct 26, 2021.
  1. Oct 26, 2021 at 8:33 PM
    Flyinhigh90
    Flyinhigh90 [OP] New Member
    Eli
    2018 tundra crew max
    BDS 7 inch coil over lift 20 inch XD820
    I’m lifting my 2018 tundra crew max with the BDS COILOVER 7 inch lift and no where in the instructions it talks about how the carrier bearing spacer goes ? Does anyone have the same lift help !!!
  2. Oct 26, 2021 at 8:39 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Welcome from CO! Pretty simple, pull the two bolts from the carrier bearing and add the shims above the U bracket and run the bolts back through and cinch her up!
    GODZILLA likes this.
  3. Oct 26, 2021 at 8:41 PM
    TXTundra2722
    2015 Black Tundra
    Agree with the above statement. This will literally be the easiest part of your lift. Welcome and don't forget to post pics of your truck!
    :thumbsup:
  4. Oct 26, 2021 at 8:56 PM
    Flyinhigh90
    Eli
    No I understand but there’s only one spacer and one bolt my question is is that normal that only one bolt for the carrier bearing with one spacer only ?
  5. Oct 26, 2021 at 9:11 PM
    18" TRD Off Road Wheels
    No. There should be 2. Look at every one of the spacer kits below.
  6. Oct 26, 2021 at 9:11 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    There should be 2
  7. Oct 26, 2021 at 9:26 PM
    Flyinhigh90
    Eli
    Ya that’s why I’m confused but if you look at this video on the carrier bearing part they only have one
    https://youtu.be/k6JJoi4AQBM
  8. Oct 26, 2021 at 9:39 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ve got the 7” BDS and I have 2.
  9. Oct 27, 2021 at 7:11 AM
    Flyinhigh90
    Eli
    Do u have a pic ?
  10. Oct 27, 2021 at 7:20 AM
    That's a time-lapse video, and shouldn't be taken as instructional. Ignore it for your purposes. You should have 2 spacers.
  11. Oct 27, 2021 at 7:51 AM
    You should look like this....one on each side of the carrier bearing.
  12. Oct 27, 2021 at 8:27 AM
    Flyinhigh90
    Eli
    Cool my 4300 dollar kit didn’t come with them so I called BDS right now and purchased it from them they said it’s optional … How the hell is that optional ???
  13. Oct 27, 2021 at 8:28 AM
    Because all lifts don't require them (small lifts) and plenty of people source their own. I think it's dumb, but those are the answers they'd give you.
  14. Oct 27, 2021 at 8:31 AM
    They are out of their minds. There are 2 different sizes depending on the lift amount, and for a reason. They correct the driveline angle. Without it, you will get a vibration during acceleration from a dead stop.
  15. Oct 27, 2021 at 9:05 AM
    Flyinhigh90
    Eli
    Ya …. But from stock to a 7 inch ? That’s a huge jump I can see the 4.5 inch not having one
    Anyway here’s before and after
    Barrett50 and mtndds98 like this.
  16. Oct 27, 2021 at 11:42 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Could always just stack washers. The drop kits are nothing special.
  17. Oct 27, 2021 at 12:46 PM
    Flyinhigh90
    Eli
    Ya I might find a 2 inch spacer for now I ordered them
  18. Oct 27, 2021 at 1:17 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That’s what I ended up doing. I had the spacers but when I added another inch in the rear I just stacked washers to get the correct angle.
  19. Oct 27, 2021 at 2:11 PM
    Flyinhigh90
    Eli
    U went thicker than the 2 inch spacers?
  20. Oct 27, 2021 at 6:41 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    They are two 1” spacers. Right now I’m at two stacks of 1.5” washers.
