Carrier bearing drop with roadmasters?
Discussion in 'Suspension' started by mattyA, May 4, 2023.
  1. May 4, 2023 at 5:47 PM
    mattyA
    mattyA [OP] New Member
    2018 CM 1794
    Level Kit front/rear TRD Pro exhaust
    I have a 2018 crewmax and a 2 inch spacer lift up front with 1.5 block lift in back. My daily driver but I do tow with some regularity (mainly a dump trailer). Bought roadmaster shocks to help with the towing and liked them but ended up with a driveline vibration that drove me nuts so I returned them.
    I bought a set of blue sumo springs but I then realized I never did a carrier bearing drop. I suspect the roadmasters may have raised things just enough to cause the vibration and a carrier drop might solve it? Should I just forget it and stick with the sumo springs? No vibration at the moment.
    And while I’m at it, any information about towing with shackles vs the block? I don’t really want to go AAL route. Thanks!
  2. May 4, 2023 at 5:49 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I’d bet it wasn’t the roadmaster springs(Roadmaster Active Suspension?) at all but the need for the carrier bearing drop, and you seriously downgraded your suspension with getting sumo springs instead. Your choice for future plans is all yours, I have the RAS HD and swear by them…
    Morebouldersplease likes this.
  3. May 4, 2023 at 5:52 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I agree it was the lack of the carrier bearing drop causing the vibration especially with a trailer hooked up.
    CoffeeAddict likes this.
  4. May 4, 2023 at 7:30 PM
    mattyA
    2018 CM 1794
    I think I’ll give the roadmasters another shot.
  5. Sep 22, 2023 at 9:05 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Did your vibration issue get resolved?
  6. Sep 23, 2023 at 12:46 AM
    mattyA
    2018 CM 1794
    It absolutely did. Love the roadmasters.
  7. Sep 23, 2023 at 5:41 AM
    ZPhilip
    Philip
    West Chester, PA
    So the carrier bearing drop kit was the solution?
  8. Sep 23, 2023 at 5:51 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Ras adds .5 to full inch of lift. You needed a CB drop. I have shackles with ras for total 2.5 inch lift with Coachbuilder drop kit plus a few washers since I'm past 2 inches. No vibration.
  9. Sep 23, 2023 at 6:19 AM
    mattyA
    2018 CM 1794
    It absolutely was.
  10. Sep 23, 2023 at 6:43 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Is a carrier drop necessary with a factory TRD PRO suspension when installing RAS?
  11. Sep 23, 2023 at 6:44 AM
    ZPhilip
    Philip
    West Chester, PA
    I have the CB 0-2” carrier drop kit and the vibration is still there.
  12. Sep 23, 2023 at 7:19 AM
    MadMaxCanon
    What's your total lift
  13. Sep 23, 2023 at 7:20 AM
    MadMaxCanon
    Probably not since it's only an inch at most
    bulldog93[QUOTED] likes this.
  14. Sep 23, 2023 at 8:28 AM
    Add a couple of washers to it and see what happens. You may need the bigger CB kit.
  15. Sep 23, 2023 at 8:35 AM
    ZPhilip
    Philip
    West Chester, PA
    I just have the RAS on stock Pro suspension, set with thicker black disc. Lift is around 1” over stock.
  16. Sep 23, 2023 at 8:35 AM
    ZPhilip
    Philip
    West Chester, PA
    Good to know. I’ll give this a shot since it’s basically free.
  17. Sep 23, 2023 at 11:43 AM
    MadMaxCanon
    Weird that you have vibration. It shouldnt
  18. Sep 23, 2023 at 12:23 PM
    ZPhilip
    Philip
    West Chester, PA
    Yep. That’s the most annoying part
  19. Sep 23, 2023 at 12:26 PM
    MadMaxCanon
    You could put a few standard washers in place of the drop kit. Are you sure it's only an inch?
  20. Sep 23, 2023 at 2:45 PM
    ZPhilip
    Philip
    West Chester, PA
    I measured and wrote it down but don’t have it in front of me. IIRC, it might have gained 1” over the CB+1 shackle height, which would be approx 1.5” over stock since I went back to stock shackles with the RAS.
  21. Sep 23, 2023 at 3:10 PM
    MadMaxCanon
    Still it's weird that drop kit should be more than sufficient
  22. Sep 23, 2023 at 3:29 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Stock Pro suspension
    RAS HD
    CB drop kit
    No issues.
    The HD gave me quite a bit more than 1” of lift. My truck has rake even with the +2” up front of the Pro suspension.
    bulldog93 likes this.
  23. Sep 24, 2023 at 5:16 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I grabbed a handful of 3/8” “plate” washers, which are pretty much square pieces of steel about 1.75” square. They’re 3/16 or 1/4” thick with a 3/8” hole. In other words, a fat square washer.
    They’re stupid cheap and you can start with 2 and go up or down till your vibe is gone. Can’t remember if I have two or three in mine. Been there for a couple years. The OEM bolts are plenty long, and mine is silky smooth now. 2” rear lift via Deavers and shackles.
  24. Sep 24, 2023 at 5:58 PM
    ZPhilip
    Philip
    West Chester, PA
    When you get a minute, could you measure how much your drop is with the 2 or 3 washers?
  25. Sep 24, 2023 at 7:58 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    It’s raining like a bitch here…. It’s about a half inch though. Maybe 5/8. I was surprised that it smoothed out as much as it did with such a small change.
    ZPhilip[QUOTED] and bulldog93 like this.
