Carrier bearing drop with a 6 in RC lift...
Discussion in 'Suspension' started by Slin2018, Sep 1, 2018.
  1. Sep 1, 2018 at 9:49 AM
    Slin2018
    Slin2018 [OP] New Member
    Shawn
    2017 SR5 CM
    6 inch lift, 20 in fuel cleavers wrapped in 20x12.5 nitto g2
    I get a little vibration when accelerating from a dead stop, then It goes away when i get to 10mph... has anyone had this issue? And did a carrier bearing drop help?.
  2. Sep 1, 2018 at 9:58 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I had the same issue and yes, the drop completely solved it for me.
  3. Sep 1, 2018 at 10:03 AM
    6" RC lift here, no shaking here, n don't have the CB drop spacers either
  4. Sep 1, 2018 at 10:06 AM
    Slin2018
    Shawn
    2017 SR5 CM
    Mine isn't that bad of a shake... might just order the bearing drop and see if that does the trick...
  5. Sep 1, 2018 at 10:09 AM
    Hope it does, might get rid of my kit, apparently it's an older version cause the rear crossmember is not cut out
