Carrier bearing drop question
Discussion in 'General Tundra Discussion' started by Sumo91, Dec 16, 2021.
  1. Dec 16, 2021 at 6:55 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I just installed some dobinson leaf springs, which provide 2.1 in of lift. Do I need a carrier bearing drop? If so, how much? I have enough material to make whatever I need, and a mountain of washers as well. I'm about to replace my u joints and carrier bearing so I'd like to have it set up correctly before installing the new stuff.
  2. Dec 16, 2021 at 6:58 PM
    Yes you need to install one.. Having the spacer installed will correct the angle and eliminate the vibration during acceleration from a dead stop. For a 2 inch lift, the carrier bearing drop down that we use from Coachbuilder is exactly 3/4 inch thick. The factory bolts are plenty long enough as well. Torque is 25 foot pounds with the truck on the ground.
    2mchfun and Sumo91[QUOTED][OP] like this.
  3. Dec 16, 2021 at 7:06 PM
    Sumo91
    TN
    Awesome! Thank you for the quick response. I'll order that, but make something in the mean time to get me by
    2mchfun likes this.
  4. Dec 16, 2021 at 7:06 PM
    Just edited my post as you hit like...lol.
    Sumo91[QUOTED][OP] likes this.
  5. Dec 16, 2021 at 7:07 PM
  6. Dec 17, 2021 at 6:00 AM
    2mchfun
    X2 about 3/4"
    Sumo91[OP] likes this.
  7. Dec 17, 2021 at 6:12 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This is the correct answer and my experience matches :thumbsup:
    Tundra234[QUOTED] and Sumo91[OP] like this.
  8. Jan 15, 2022 at 5:34 AM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Anyone know the max drop you'd want to do on the CB bracket? Just dropped mine about 1.25" and it still has the shudder. I need to measure driveline angles to get some more data but just curious if others have dropped much more than 1.5"
  9. Jan 15, 2022 at 6:03 AM
    What size lift are you running?
  10. Jan 15, 2022 at 6:07 AM
    Tundra2Yak
    2016 1794 4x4 CM
    6" with 35s.
    Also thought I read or watched something about leaf spring shims? Was really hoping the CB drop would take care of the shudder but the lift size may require more drop im assuming.
  11. Jan 15, 2022 at 6:35 AM
    There are leaf spring shims but they are for leveling the lean condition. Do you have the diff drop installed?
  12. Jan 15, 2022 at 7:02 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Post a pic of your carrier bearing, please.
  13. Jan 15, 2022 at 7:20 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Yes, the diff drop seems pretty big. Not just spacers but a whole new piece.
    Also, just crawled under the truck and measured the spacers they put in. They're just 1" aluminum bar stock with new bolts. Probably needs more based on what I've read.
  14. Jan 15, 2022 at 7:24 AM
    19TurdPro
    2019 Tundra TRD Pro
    Would you please take pic of your bearing and post it?
    The mounting flange of the bearing is offset from the center axis by about 5/8". I can't count how many times I've seen the carrier bearing installed upside down on these forums. That alone will cause major shudder.
  15. Jan 15, 2022 at 7:36 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have the 2" CB shackles. This is the drop on my carrier. I also run a 6" lift.
  16. Jan 15, 2022 at 7:39 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks for the pic. Just to clarify, thats a 2" spacer you're running?
    Here's mine with the 1" spacer. Orientation seems to be correct with the single hole down.
  17. Jan 15, 2022 at 7:49 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No, 3/4". My shackles are 2" lift (1.25" real)
    Prostar 190 likes this.
  18. Jan 15, 2022 at 7:53 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Ahh, gotcha. Thanks for clarifying. That pic is deceiving, spacer looks way bigger than the one on mine.
  19. Jan 15, 2022 at 8:48 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have you thought about decreasing the amount of drop? You may be too low.
  20. Jan 15, 2022 at 1:29 PM
    Tundra2Yak
    2016 1794 4x4 CM
    That may be a good suggestion. Just put it on yesterday and drove about 40 miles.
  21. Jan 15, 2022 at 3:09 PM
    My 6" also has a 3/4" drop with zero shutter.
  22. Jan 15, 2022 at 3:57 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks. I'll try some smaller shims. How much lift you have in the rear on yours?
  23. Jan 15, 2022 at 4:24 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Spicer has a really good guide on their site. It can help anyone dial in their driveline angles.
    Cruzer likes this.
  24. Jan 15, 2022 at 4:34 PM
    I would say 5"
  25. Jan 16, 2022 at 5:32 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Checked driveline angles and it looks like I am a bit too low on paper.
    Working angle at the diff u joint is ~6deg vs ~4deg at CB. Bringing it back up should bring those closer together and bring the working angle closer to 0 at the transfer case. Right now tcase working angle is ~0.8deg.
    texasrho83 likes this.
  26. Jan 17, 2022 at 6:42 AM
    2mchfun
    With that much lift, you should add traction bars, pretty sure your problem is axle wrap.
  27. Jan 17, 2022 at 6:52 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The 6/35 setup is pretty common and I can count the time I've seen trac bars on one hand
  28. Jan 17, 2022 at 7:07 AM
    2mchfun
    Does that make it right or wrong? Minimizing axle wrap is always a good idea. Pretty sure many of those you see eat u joints faster than they should.
  29. Jan 17, 2022 at 7:17 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just sayin that I doubt all those trucks are having axle wrap.
  30. Jan 17, 2022 at 8:18 AM
    Tundra2Yak
    2016 1794 4x4 CM
    I was thinking that may be part of the issue since it is worse under heavier acceleration.
    I did loosen the bolts and pushed the CB over as far as I could to get better alignment between the driveshafts. Still not completely straight when taping a string to both ends but its as good as I could get it. That alone seemed to help a bit.
    Never heard of a traction bar, will need to research.
    2mchfun[QUOTED] likes this.
