Cargo Rail Options for '13 SR5 dbl cab 4x4
Discussion in '2nd Gen Tundras (2007-2013)' started by Woodcycl, Apr 16, 2017.
  1. Apr 16, 2017 at 9:33 AM
    Woodcycl
    Woodcycl [OP] New Member
    Southern Indiana
    2013 SR5 TRD 5.7L Red 4WD Dbl Cab
    20in Rims
    First time truck owner and picked up the 2013 SR5 TRD Dbl Cab 4x4 yesterday with only 45000 miles!
    Needing to add cargo rails asap.
    Any options, recommendations, things to watch out for, etc are appreciated.
    Many thanks,
    Brian in S. IN
    Jsena likes this.
  2. Apr 16, 2017 at 11:10 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  3. Apr 16, 2017 at 11:46 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Brian, go with the Unistrut if you don't want the OEM bedrails.
    BTW, welcome to the forum from Las Vegas!!
  4. Apr 17, 2017 at 6:54 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Those look great and I'm not opposed to DIY, however, I'm not sure how to install them given I have a bedliner without any access to the truck bed itself. Looks like the Toyota Tundra OEM rails have an optional hardware kit when a bed liner is already installed (BEDLINER RETAINER BRACKET KIT IS PT271-34070-HW).
    Also, not sure what size is considered standard for all accessories that are out there.
  5. Apr 17, 2017 at 8:41 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Welcome bud.
    I'm in the process of building/installing the DIY rails in my '14 double cab. I could be wrong but I do believe the DC bed is the same size despite the 2nd gen-3rd gen difference. My rails measured at 5'6" on the sides (leaving several inches on either end to slide things onto the rail) and 4'6" on the cab end.
    What bedliner do you have?
  6. Apr 17, 2017 at 9:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Someone just installed some unistrut with their bedliner. I think it was @CM-LENNY. Maybe he'll chime in.
  7. Apr 18, 2017 at 1:48 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Here's my bed liner ... looks like the Toyota branded oem one possibly?
  8. Apr 18, 2017 at 1:48 PM
    Woodcycl
    Southern Indiana
    20in Rims
  9. Apr 18, 2017 at 2:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This is where the holes are where circled. The arrow is a non threaded hole but shows about the height of the holes. I bet if you got a thumb tack and pushed around those areas, you would be able to find the threads.
  10. Apr 18, 2017 at 5:48 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Hall I know this bed! That's my truck, the circled locations are thed correct areas. I used a sharp picknife to locate the holes through the bedliner.
  11. Apr 18, 2017 at 7:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. I thought it was my truck when I posted the pic. And then I noticed the ladders are different than mine. And then I noticed the truck was blue. :anonymous:
    gosolo likes this.
  12. Apr 18, 2017 at 7:03 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Awesome! Thanks Joonbug and Alloutdrs1!
    Any thoughts on threaded holes on the front against the back of the cab? I'd like to put one of up there until I get a toolbox.
  13. Apr 18, 2017 at 7:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Sorry bud, I have my retractable tonneau box there.
  14. Apr 18, 2017 at 7:23 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Brian, I did the uni strut DIY set-up and it worked well. I think I posted it in the " what have you done to your 3rd Gen" area. Do you need the measurements on where to drill through the bed liner ?
  15. Apr 18, 2017 at 7:30 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Yes, that would be great CM. Also, which UniStrut did you purchase? I see it under different names by different sellers (HD, Lowes, Ace, Online, etc.). And, which size did you get (not length, but dimensions)?
    Many thanks CM!
  16. Apr 18, 2017 at 7:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Brian, what are you going to mount onto the unistrut?
  17. Apr 18, 2017 at 7:36 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Initially Bike fork mounts as we are cyclists. And, will be mounting a tandem to it. So, do need the heavier options where available. Otherwise, just tie down loops and similar.
    joonbug[QUOTED] likes this.
  18. Apr 18, 2017 at 7:38 PM
    CM-LENNY
    San Diego, CA
    I used the shallow strut ( 13/16 I think ). It will flush out with the bed rails. Give me a minute and I will grab the measurements.
  19. Apr 18, 2017 at 7:57 PM
    CM-LENNY
    San Diego, CA
    Look at my post 6534 under "What have you done to your 3rd Gen". If you butt your tape measure to the front of the bed (metal portion, not the bed liner), 5-1/4, 18-1/4, 31-1/8, 44, 56-7/8. Come down 3/4" from bottom of bed rail (metal edge). I used a paint pen to mark on the bed liner. Also used a 3/4" block of wood to use as a marking guide. After marking the bed liner, pull it away to do the hole saw and trim the rear wings on the liner which will allow it to sit tighter. I failed to pull the liner away on the first side, and my pilot bit in the hole saw found the 6mm tapped hole in the bed and stripped it. I drilled and re-tapped that one hole to the next size. Good luck with all. Yell with any questions.
    Woodcycl[OP] likes this.
  20. Apr 18, 2017 at 8:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wait, he has a double cab! Is this for the front of bed or sides?
  21. Apr 18, 2017 at 8:04 PM
    CM-LENNY
    San Diego, CA
    Didn't even look at that. OOPS.......I wonder if the first holes are all the same and just continue out the back ?
  22. Apr 18, 2017 at 8:05 PM
    CM-LENNY
    San Diego, CA
    Sides........
  23. Apr 18, 2017 at 8:25 PM
    Help New Member
    Ryan
    Tucson, AZ
    My DC bed is bare metal with all those holes exposed. I'll take measurements tomorrow.
  24. Apr 18, 2017 at 9:57 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Didn't even think about CM vs DC. Thanks for the info anyway CM.
    Yes, that's great Help! I appreciate it.
    CM-LENNY likes this.
  25. Apr 19, 2017 at 5:56 PM
    Help New Member
    Ryan
    Tucson, AZ
    I only measured the pre-existing threaded holes. There were a couple extra random ones that may not be factory lol These should get you in the ballpark (assuming I don't need my measuring tape calibrated ;)
    Cab: 5 holes total, mirrored around center at 30 1/4". from right or left: 8 3/4", 20", 30 1/4"
    Sides: 6 total per side. I'm assuming they're matching on both sides of the bed. Starting from the cab: 5 1/2", 17 1/2", 30 1/4", 43 1/8", 56", 68 7/8"
    From other threads I've seen, it looks like a couple guys have established that the holes fit an M6 x 1.0 bolt
    edit: it was really bothering me that they weren't evenly spaced along the sides of the bed so I triple checked. Both sides are similar, but there seems to be about 1/4-1/2" of acceptable "play" on where they drilled each hole. My OCD is going nuts right now. Looks like they generally tried for 12.75" between most holes.
    joonbug likes this.
  26. Apr 19, 2017 at 6:48 PM
    Woodcycl
    Southern Indiana
    20in Rims
    Thanks for the measurements Help! I really appreciate it. I'll test a few on mine asap and report back.
    Help likes this.
