Cargo Light Wire on 2019 Limited
Discussion in 'Lighting' started by mil3sdavis, Jan 3, 2020.
  1. Jan 3, 2020 at 9:40 AM
    mil3sdavis
    mil3sdavis [OP] New Member
    Dayton, OH
    2019 Cavalry Blue Tundra Limited - Crew Max
    I'm looking to install LED strip lights in the bed and would like to tie into the cargo light circuit but don't really want to go through the process of trial and error to figure out which wire it is if I don't have to. I've looked all over this forum and a few others trying to find info for the 2019 model but haven't had any luck.
    I originally was planning on pulling power from the +12v line on the 7-pin trailer connector, but figured out that it is only live when the truck is running. If anyone knows of an alternate way to have the lights powered with the truck off that doesn't require running power all the way to the battery that would also be appreciated. At this point I think that the cargo light is probably just the simplest way.
  2. Jan 3, 2020 at 10:08 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This may or may not help.
    It is the schematic from a 2015 cargo light switch.
    You can tap into that brown wire, I think it runs along the drivers side door sill between the switch relay and the light..
  3. Jan 3, 2020 at 10:45 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It's probably the same pin position as my 2018 and maybe a different color, but I can't remember where I originally found the info for the one I tapped.. I know that it's in the drivers side sill panel, and I THINK it was the smaller pink wire... I'd need to go out and pop the covers off to know for sure. I'll see what I can find.
  4. Jan 3, 2020 at 10:53 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Jan 4, 2020 at 9:20 AM
    mil3sdavis
    Dayton, OH
  6. Jan 4, 2020 at 10:01 AM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    I just added the OEM LED's in my bed following this post and with these instructions in the PDF below had my 2019 Pro the wire was blue which tied into the cargo light.
  7. Jan 4, 2020 at 10:37 AM
    mil3sdavis
    Dayton, OH
    Blue... awesome! I'll check into that.
    LyonKing[QUOTED] likes this.
  8. Oct 7, 2020 at 9:25 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Lifesaver ... thank you so much
