Cargo light power wire color- 2018 SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by panicman, Apr 20, 2019.
  1. Apr 20, 2019 at 12:11 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Help! What color is positive (power) for the cargo light on a 2018?
    Colors running to cargo light switch are:
    Green
    Purple
    Blue
    White x 2
    Black
    Thank you!
  2. Apr 20, 2019 at 1:05 PM
    panicman
    Eric
  3. Apr 20, 2019 at 7:10 PM
    panicman
    Eric
    Isn’t someone going to help that poor man?
  4. Apr 20, 2019 at 7:11 PM
    panicman
    Eric
    C’mon. Somebody here had to add lights to an 18 SR5.
    Anyone have a wiring diagram?
  5. Apr 20, 2019 at 8:00 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Dang it, I had my dash apart today, I grabbed a wire from behind the dash, I'll post a pic sometime tomortow.
    panicman[OP] likes this.
  6. Apr 20, 2019 at 8:12 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Its pink if you pick it up at the rear seat, driver side foot area.
    Search "bed light install" on here.
    panicman[OP] and silverhack like this.
  7. Apr 20, 2019 at 8:41 PM
    panicman
    Eric
    Rescuers!
    Thank you!!
  8. Apr 21, 2019 at 1:14 AM
    panicman
    Eric
    Tried this and there are a couple of pink wires in the sleeve.
  9. Apr 21, 2019 at 6:51 AM
    HappyGilmore
    Trent
    Lakewood CA
    It's hard to tell but it's the thicker one. I just probed it with a test light and had someone turn the cargo lights on and off to confirm.
  10. Apr 21, 2019 at 9:34 AM
    panicman
    Eric
    How did you probe?
    I’d feel better if I had a positap,but I can’t find them anywhere.
  11. Apr 21, 2019 at 10:01 AM
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Here you go......
    panicman[OP] and HappyGilmore like this.
  12. Apr 21, 2019 at 12:07 PM
    HappyGilmore
    Trent
    Lakewood CA
    My test light has a sharp point and I just pushed it through the insulation into the wire. Not ideal for external wires but I feel like it's ok for interior wires. It kinda self heals after you pull it out, it doesn't leave wire exposed.
    panicman[QUOTED][OP] likes this.
  13. Apr 21, 2019 at 1:32 PM
    panicman
    Eric
    Maybe ill give that a try.
  14. Apr 21, 2019 at 1:50 PM
    panicman
    Eric
    Thank you 3mxdivr!!
  15. Apr 21, 2019 at 2:19 PM
    panicman
    Eric
    So that wiring diagram looks like the back of the cargo light switch- I took a picture of mine.
    The installation thread I followed tapped into the power wire coming off the block behind the dash.
  16. Apr 21, 2019 at 7:15 PM
    HappyGilmore
    Trent
    Lakewood CA
    I assume youre installing bed lights or outside lights of some sort. Either place to tap into is fine. It was just less work for me to grab it at the rear passenger area, rather than go to the dash and take apart the panels.
  17. Apr 21, 2019 at 7:45 PM
    panicman
    Eric
    These are puddle lights mounted under the side mirrors. I could splice in where you describe easily by adding 3 ft or so of wire. Close quarters behind the dash.
    HappyGilmore likes this.
  18. Jul 17, 2019 at 5:31 PM
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    So which wire did you tap into on the block? Trying to wire some puddle lights on a 2019 and can’t get them to light up.
  19. Jul 17, 2019 at 5:42 PM
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    Disregard....of course after posting it I figure it out after hours thinking I had wrong pink wire...
    panicman[OP] and JoshuaA like this.
  20. Jul 17, 2019 at 6:42 PM
    panicman
    Eric
    Glad you found it. I ended up going into the driver side floor near the door to use the pink wire in there- lots more room to work.
    americanaaron and HappyGilmore like this.
  21. Jul 17, 2019 at 6:55 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    like this..
  22. Dec 28, 2019 at 11:07 AM
    2chains
    2chains New Member
    Southern Ablerta
    ok thanks for posting.
    I think I maybe confused? I'm still learning about electrical stuff and want to fully understand. Can someone clarify?
    Based on the op's pic of the cargo light switch and the diagram above pin4 blue wire which is above wires in pin 9/10 is -'ve wire?
    When looking at page 12 of the 2018 Toyota factory install guide for cargo bedlight's it shows blue wire as power?
  23. Dec 28, 2019 at 1:15 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Maybe this can help?
  24. Dec 28, 2019 at 1:43 PM
    2chains
    2chains New Member
    Southern Ablerta
    ok I think I figured it out...the pic is from front of switch and diagram is facing back. :oops:
  25. Dec 28, 2019 at 2:38 PM
    Joe333x
    Joe333x Member
    Boston
    Post back when you know for sure, plan to do some wiring to the cargo light myself for my cap when it gets installed. Part of the reason I have the wiring diagram.
  26. Dec 28, 2019 at 7:03 PM
    2chains
    2chains New Member
    Southern Ablerta
    ok sure, those connectors in the Toyota PDF are at the dashboard which you would have to pull apart. I'll probably want to do what the op did and tie in at the larger pink wire at rear driver side sill. That way you don't have to take out the front kick plate just pull the rear driver sill.
  27. Feb 11, 2020 at 4:00 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Thanks guys for doing the hard work here!
  28. Feb 11, 2020 at 4:19 AM
    coTony
    Tony
    Montrose, CO
    FWIW
    I replaced my third brake light and many other things on my 2018 and the wiring harness changed for the 2018's and above. The first wiring diagram I seen said 2016 and above which obviously was printed before 2018. When I installed the brake light the lights were swapped. I had to modify the light connector to get it to work correctly. Sorry I have no pics to share, was pretty pissed doing this since I thought it was be a slam dunk but took longer than what I planned for.
    Sounds like you got it figured out!
  29. Jul 13, 2020 at 2:20 PM
    brandoncip
    brandoncip New Member
    Brandon
    Hamilton
    2019 SR5 Double Cab Off Road
    I'm trying this out myself, if I use the pink wire from the driver side sill, will my bed lights operate the same as OEM cargo light?
  30. Jul 14, 2020 at 9:38 AM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Yes.
