Cargo containment...??
Discussion in '2.5 Gen Tundras (2014-2021)' started by tgo, Oct 27, 2018.
  1. Oct 27, 2018 at 6:50 PM
    tgo
    tgo [OP] New Member
    Central VA
    2018 Limited CM Silver Sky
    Forgive me in advance folks if this has been discussed. I have been unable to locate it.
    I want to purchase some type of "containment system" that hooks on the OEM rail system. I don't know the key words to use so I will try to explain what I'm looking for as best as I can.
    My truck is more of a family truck than anything. It routinely has two car seats in the back seat. I am looking for something like a bed extender when it is folded into the bed. I am hoping that there is something produced that is made to hook on the adjustable rail cleats that would create a shallow/shorter bed from the tailgate area. Creating enough space and containment that would prevent groceries and small items from sliding around.
    Thanks in advance!
  2. Oct 27, 2018 at 6:57 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    A Bed Extender sounds like what you are looking for. Many makes and models.
  3. Oct 27, 2018 at 6:59 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    Does your ideal system need to be waterproof or is it open to the elements?
  4. Oct 27, 2018 at 6:59 PM
    tgo
    tgo [OP] New Member
    Central VA
    Yes.... That would work but I am looking for something that is a little more adjustable. Was hoping to mount to the cleats and move the cleats in the bed where i needed the divide to be.
  5. Oct 27, 2018 at 7:01 PM
    tgo
    tgo [OP] New Member
    Central VA
    I plan to put a bed cover on. In a perfect world, what I'm looking for would attach to the cleats below the cover.
  6. Oct 27, 2018 at 7:16 PM
    ttttttttttt
    ttttttttttt New Member
    2018 CrewMax Limited
    I'd like to find the same thing. My previous truck (05 Nissan Frontier) the bed extender attached to the rail system so you could slide it around and could create a small space in the bed near the back of the cab. I used it for that far more than I did extending the bed. I've looked all over and haven't been able to find anything similar for Tundra.
    Frankly losing this and the crappy jbl sound system are the only regrets I've encountered since upgrading to the tundra 6 months ago.
  7. Oct 27, 2018 at 7:32 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
  8. Oct 27, 2018 at 7:39 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Bed divider?
  9. Oct 27, 2018 at 7:44 PM
    Bill_2018_Tundra
    Bill_2018_Tundra New Member
    2018 Tundra Limited Crewmax TRD Off Road
    Line-X Premium AMP Powersteps
    Pudge is quicker. That is the divider ^^^ I am linking to
    They used to make this exact divider OEM. I am linking to Toyota of Cool Springs (discontinued), but it appears Amazon may still carry it. One of the Amazon Q/A states it may not work with a tonneau. I personally have an AMP research bed xtender that I use to provide the contained space back near the tailgate to keep stuff from sliding around under my tonneau.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-cargo-divider-pt76734070/?c=Zz1jYXJnby1tYW5hZ2VtZW50JnM9Y2FyZ28tYXJlYSZhPXRveW90YSZvPXR1bmRyYSZ5PTIwMTgmdD1saW1pdGVkJmU9NS03bC12OC1nYXM=
    Pudge likes this.
  10. Oct 27, 2018 at 8:12 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Do these swivel out easily? Always was intrigued by one of these
  11. Oct 27, 2018 at 8:29 PM
    ttttttttttt
    Thanks!
    I've thought about these but guess I was holding out until I could find the dual purpose extender I had before. But I'll probably give up and pick one up eventually.
    I have noticed that things don't slide around nearly as much on the toyota plastic bed liner my tundra came with. I think it said something about being non-slip?
    Also I do wonder though if it would be possible to still use the extender if I had some custom hardware made. Would it even fit around the wheel well? I have a buddy that could make these for me.
  12. Oct 27, 2018 at 8:36 PM
    Pudge
    CT
    I don't think the extender will fit between wheelwells, I like the idea I'd custom brackets though. The divider is made to fit between the wheelwells but to me it's a tradeoff because it leaves gaps in the sides if you choose to slide it back toward the tailgate
  13. Oct 28, 2018 at 7:02 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’ve read the divider works with the tonneau cover but you need to flip the rail bracket upside down so the tightening knob is underneath.
  14. Oct 28, 2018 at 9:00 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    That's pretty cool. Where did you get that?
  15. Oct 28, 2018 at 9:15 AM
    Trooper2
    JR
    Very easy, Aluminum very light.
    bigzrs01[QUOTED] likes this.
  16. Oct 29, 2018 at 1:10 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    We show them unavailable because of the shipping issues we have had with these. We have shipped out many that have become damaged during the shipping process, and UPS wouldn't pony up for the damages.
  17. Oct 29, 2018 at 1:43 PM
    15whtrd
    15whtrd Mr. Blonde
    You could also use a 2 x 6 or 2 x 10. The bed has little notches made just for this. Downside is there is only two locations they can be used. In front of the wheel wells or behind. Right now I use one of those ratcheting extension poles so I can set stuff just inside the tailgate without it flying forward.
    Reese Explore 1390600 40" x 70" Ratcheting Cargo Bar https://www.amazon.com/dp/B01414B9HI/ref=cm_sw_r_cp_api_1d31Bb0NYAEVG
  18. Oct 29, 2018 at 1:45 PM
    15whtrd
    15whtrd Mr. Blonde
  19. Oct 29, 2018 at 3:16 PM
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    This is what I use now, and picked mi e up at Harbor Freight. Sam's provided the collapsible crates.
    15whtrd[QUOTED] likes this.
  20. Oct 29, 2018 at 3:45 PM
    15whtrd
    15whtrd Mr. Blonde
    The collapsible crates are a good idea. I’m gonna keep my eye out.
  21. Oct 29, 2018 at 4:01 PM
    tgo
    tgo [OP] New Member
    Central VA
    Thanks for all of the ideas folks!
  22. Oct 29, 2018 at 4:15 PM
    Sam's Club, BJ's Club and Costco sell them. I bought them to move my daughter in and out of college each year.
  23. Oct 29, 2018 at 4:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I got a date with Cosco this Friday!
  24. Oct 29, 2018 at 5:31 PM
    :thumbsup:
  25. Nov 13, 2018 at 11:45 PM
    Drew05
    Drew05 New Member
    Any pics of this?
  26. Nov 14, 2018 at 5:52 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  27. Nov 14, 2018 at 7:59 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
  28. Jan 17, 2019 at 9:50 PM
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Sounds like a great idea! Can someone confirm this really works? I have a tonneau cover and would like to know if this idea will work before buying that divider. For that matter, is that tightening knob really needed? The divider can't slide out of the bracket, so why that knob?
    Thanks!!
  29. Jan 18, 2019 at 8:35 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
  30. Jan 18, 2019 at 10:18 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I searched high and low for containment and finally went simple. I’ve got a bed cover and wanted a way to haul groceries, etc. and to really just have stuff that was not in plain view in the cab. I got a couple of heavy plastic storage bins from Home Depot and use bungee cords to hook them to bed rails or the bed tie downs. the bungees just keep the containers from sliding around too much and I can just pull on the cord to pull them out. Simple and easy. When I need the whole bed I just pull them out and put them in the backseat or leave them at home.
    19Tundra77 likes this.
