Car play cable question
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by elgerardo, Jun 8, 2025 at 9:49 AM.
  1. Jun 8, 2025 at 9:49 AM
    elgerardo
    elgerardo [OP] New Member
    Hi. I have a 2021 trd pro.
    I’ve seen some videos online of people having a usb c port inside center console. I only have the “lighter” port.
    I have the 3 usb a ports below the front dash.
    Anyone know if it’s possible to put some type of usb c port in the 2021 tundra?
    what are people doing for CarPlay? Or do you just wire it with the usb a cord. seems like such a bummer to have it so visible with no way to tuck it away.
    Hopefully I’ve just missed it somewhere.
    thanks
  2. Jun 8, 2025 at 10:06 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Do you have a stock Entune or aftermarket radio?
    Are you wanting the USB C to connect to the radio?
    I don't understand why you have a loose USB cord and not a plug in the dash.
  3. Jun 8, 2025 at 10:07 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The USB port on the left is your data port for wired CarPlay. The other 2 USB ports are just charging ports.
    Many of us run a dongle that essentially gives you wireless CarPlay (just leave the dongle plugged in all the time). Then you can leave your phone in your pocket, bag, etc... and don't have a bunch of wires all plugged in!! Also, it seems like eliminate a ton of quirks of the wired CarPlay system in our rigs...
    https://www.amazon.com/dp/B0D8754QT6?ref=ppx_yo2ov_dt_b_fed_asin_title
    Regarding the usb C ports, I'd recommend replacing the 2 existing USB ports (to the right of the data port) with Toyota OE part #85532-48080
    Dual USB-C connector; it's out of a Prius but fits the same connectors... @French Avocado installed one recently, here's his post showing what it looks like: 102855
    PS>>> Don't forget to check your current head unit firmware for the latest versions. Here's a link on how to do that as well.. https://www.toyota.com/firmware-updates
    WhiteSR5 likes this.
  4. Jun 8, 2025 at 10:41 AM
    elgerardo
    @Tripleconpanna Thank so much. I just told delivery of my truck so I’m probably asking dumb questions.
    I will look into that dongle you shared. I’ve only really seen about one called carlinkit. But reviews seem hit or miss.
    Tripleconpanna likes this.
  5. Jun 8, 2025 at 11:05 AM
    Tripleconpanna
    :hattip:
    Not dumb questions at all, as we all learn from somewhere. BTW Congratulations on your new rig!!! What color did you end up with??
    The dongle link I sent you is the same one I've been running for a couple of months now, and I like it. Prior to that I had an Ottocast dongle that worked well also, but it had a cord on it that plugged in to the data port. So, to eliminate that cord, I went with this new one. It apparently is newer technology (faster, etc.) than the Ottocast one I had been running.
