Car out of storage. Need oil change?
Discussion in 'General Tundra Discussion' started by BlueFalconActual, Aug 27, 2016.
  1. Aug 27, 2016 at 7:50 AM
    BlueFalconActual
    BlueFalconActual [OP] Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Hey guys, I have a question about my wife's car.
    We got back from being stationed in Japan for three years last month and are about to take my wife's car out of storage. The storage place put fuel stabilizer in it when they received it and started it, cycled the heat and AC, drove it around the lot twice a month for 3 years and filled it up with fresh gas yesterday.
    The question I have is if I have to change the oil immediately upon recieving it. I plan on doing it anyway within the next month but I won't have my garage and tools out of storage for at least a couple of weeks. I was under the impression that it had to be changed immediately, but then someone pointed out that emergency generators have oil in them for years at a time and never get changed because oil doesn't deteriorate like gas does. Any input would be appreciated.
  2. Aug 27, 2016 at 8:32 AM
  3. Aug 27, 2016 at 9:30 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I'd change it immediately. While i too would want someone to start my car and take it for a quick drive every couple of weeks to keep oil where it needed to be, unless they got it up to full running temperature for a sustained period of time, you would most likely get an accumulation of condensation that would work it's way into the engine oil.
    For a while, with my project car, i would start it every week or two and try to get it to operating temperature but even with that... one time i changed the oil i figured i must have had a head gasket leak because the oil i took out was so milky. Now that it's running and i drive it, and after a LOT of testing, I know I don't have a head gasket problem and it must have been condensation.
    If it was stored in one of the more humid states, it just makes it worse. so my vote would be to change it.
    With regards to the generator thing though. Yes.. if the oil sits there and isn't run through an engine, it's not as much of a problem, but they probably take other precautions that mean they don't have to start the engine every two weeks. Even while they sit there unused for sustained periods of time, I'm quite sure they get routine maintenance based on time rather than use
    Law323 likes this.
  4. Aug 27, 2016 at 9:40 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Oil will hold its molecular structure for about a year then it breaks down. Change it and dont take chances on your car over the price of $40
    Law323 likes this.
  5. Aug 27, 2016 at 10:56 AM
    SLOBlueE90
    SLOBlueE90 New Member
    Bob
    San Jose
    2016 White Tundra Platinum
    Engine oil is relatively inexpensive; new engines are not. Incidentally, if you find yourself in this position again, change the oil immediately before you put your ride in storage too.
  6. Aug 27, 2016 at 11:00 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Thanks all. It was changed before it was stored and does get to operating temperature twice a month. Also it is stored in CA, so low humidity. Either way, I'll get it changed.
