Capless gas cap
Discussion in 'General Tundra Discussion' started by jeremyd, Jan 13, 2019.
  1. Jan 13, 2019 at 5:36 AM
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
  2. Jan 13, 2019 at 5:41 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    According to them, not compatible with my truck, 2018 SR5, CM.
    Black Wolf and jeremyd[OP] like this.
  3. Jan 13, 2019 at 5:44 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    yea it's weird, works for a Tacoma but not the Tundra. Must be a special system..
    I just found this on the Stant website.
    Tundra 2014-2015; USK57, From 09/2014 12427 Threaded, Purple 2013; FLEX 12410 Threaded 2012; FLEX 12427 Threaded, Purple 2007-2011; FLEX 12410 Threaded 2003-2006; GAS 12422 Quick-On, Tan w/
  4. Jan 13, 2019 at 6:00 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Don't think I'd be trusting it anyhow, whatever seals it has to wear out sooner or later. And I'm just not that big of a rush to fill up the tank that I can't unscrew the cap a quarter of a turn and take it off.
    But others may dig it.
    Darkness, NewImprovedRon and Y0TA PR0 like this.
  5. Jan 13, 2019 at 6:14 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Just to clarify, I retired with two full blown pensions at the age of 51. I'm definitely not lazy. I'm simply thinking outside the box. Other manufactures are switching to this capless gas cap.
    Prostar 190 and 15whtrd like this.
  6. Jan 13, 2019 at 6:24 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I'm jealous...I'm 55, at this rate i'll be 80 before retired...Didn't mean to imply anything about one's work ethics.
  7. Jan 13, 2019 at 6:49 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    If it fails and leaks water into your fuel tank how would you know until it was too late?
    Stant probably isn't going to cover the repairs on your truck if there is damage done from contaminated fuel.
  8. Jan 13, 2019 at 8:40 AM
    greasemnky
    greasemnky New Member
    Better question, does anyone make a real gas cap to replace the factory capless ones! Our mustang has one and I hate it!!
    Watt maker likes this.
  9. Jan 13, 2019 at 11:48 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    What do you hate about it ?
  10. Jan 13, 2019 at 3:03 PM
    nate2018
    nate2018 New Member
    Nate
    2016 Tundra Crewmax Limited
    My work truck 2016 F150 has had one. Using for the last 2 years with no issues. Some people look at me weird at the pump like I don't have a cap at all lol. I kinda like it cause touching the gas cap, etc less gas stink on your hands.
    jeremyd[OP] likes this.
  11. Jan 13, 2019 at 3:21 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Same with my work F-150, no issues, but it’s a Ford so something will go wrong
    15whtrd likes this.
  12. Jan 13, 2019 at 3:23 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Lol!!! Best joke ever!
    Darkness likes this.
  13. Jan 13, 2019 at 3:29 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Years ago I put a fill through cap on my Celica. Never any issues. Gas door is going to keep the rain out if your seal fails a little.
    I only stopped using it as recent vehicles all have the gas cap attached.
    some systems are vented, some are non-vented - that is likely the difference if one will work with your vehicle.
    Oh - if your state test's gas cap seal at emissions, you can't use these fill-through caps unless state books say your vehicle should have one (factory equipped).
    jeremyd[OP] and 15whtrd like this.
  14. Jan 13, 2019 at 3:30 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Why do you want this? It’s pretty easy to spin a cap off and all I see are potential issues.
    stuckinohio and NUDRAT like this.
  15. Jan 13, 2019 at 3:31 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    How fast is a spring going to go soft? How fast will a rubber seal go bad? A decade?
    I like them as they are arthritis friendly.
    BTBAKER[QUOTED] likes this.
  16. Jan 13, 2019 at 3:32 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Got it. I can understand it if you have some type of physical concern.
    15whtrd and NUDRAT[QUOTED] like this.
  17. Jan 13, 2019 at 4:58 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I'm gonna have to work til I'm dead, and then another week past that!
    JC303 and Moon Puppy[QUOTED] like this.
  18. Jan 13, 2019 at 5:00 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Sell your carcass to science, keeps the money coming in after. :(
  19. Jan 13, 2019 at 6:17 PM
    nate2018
    nate2018 New Member
    Nate
    Lol well your gonna love this. Fuel pump went out at only 46k miles already
  20. Jan 13, 2019 at 6:20 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I'm just thinking outside the box. That's ok to do right ? Or is there some kind of rule preventing that.
    CMB likes this.
  21. Jan 14, 2019 at 3:30 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Yep, that's why this cap caught my eye. I've had both hands 'repaired' and it's tougher than it should be getting gas cap tight enough. Plus, my hearing is such that I've set codes on the dash because of not hearing the gas cap "click." For the price, it'll be worth a try for me...….. Just checked Stant's website, (thanks jeremyd) and they don't list any help for us. Guess I'll keep '2-handing' the gas cap!
  22. Jan 14, 2019 at 5:23 AM
    Decade1000
    Decade1000 New Member
    MALABAR , FL
    I don't care for these not having something to block the hole at the top as well . I wouldn't want to worry about what has crawled or fallen into that nozzle hole so once you put in the gas pump in it just pushed things through the rest of the way .
    landphil likes this.
  23. Jan 17, 2019 at 5:28 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Oh. Mine has a flap. Here's the first hit I found for a "fill through gas cap"
    https://www.haganauto.com/product_p/fdcap.htm
    It has a center flap that pushes out of the way - no unscrewing. Seems to work w/ both types of venting.
    and an article discussing pros & cons of capless gas tanks.
    https://www.carprousa.com/The-Pros-and-Cons-of-Increasingly-Popular-Capless-Gas-Tanks/a/5
  24. Jan 17, 2019 at 5:31 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    My wife's Honda Pilot has one of these. No issues with it at all.
  25. Jan 17, 2019 at 5:34 AM
    15whtrd
    15whtrd Mr. Blonde
    I swear I must be slightly dyslexic. Every time I pass by this thread, I see it as “assless chaps”
  26. Jan 17, 2019 at 5:39 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    kinky. :thumbsup:
    jeremyd[OP] and 15whtrd[QUOTED] like this.
  27. Jan 17, 2019 at 5:40 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    15whtrd[QUOTED] likes this.
  28. Jan 17, 2019 at 5:45 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Do our Tundras error code when the stock gas cap is loose? I'm actually fine with OEM vs this mod.
  29. Jan 17, 2019 at 6:34 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    without having the actual fuel door sealing out water/dirt etc, I think this would lead to other issues. If you look at factory capless setups, the door itself has a seal on it that keeps crap out of the area where the filler is.
    Also, when Ram went to a capless design on the diesels, they added more fuel filters and a bigger water separator that required more frequent draining. So even then, they knew that the design wasn't the best.
  30. Jan 17, 2019 at 7:36 AM
    CMB
    CMB New Member
    Cecil County MD.
    With my Arthritic hands and half-deaf hearing, that "capless"cap could really help. I've searched and there doesn't look like there's one available for my 2010 though.:notsure: As far as wearing-out, I'm thinking the constant removing/re-attaching the regular caps would contribute to that. All there should be to 'fail' on the capless models, might be the flap and a shot of lube every now and then may help there.
