Can't turn stock radio volume down at all
Discussion in 'Audio & Video' started by lamps, Sep 21, 2021.
  1. Sep 21, 2021 at 12:44 PM
    lamps
    lamps [OP] New Member
    Russ
    2007 Tundra
    all original
    I have a still new 2007 monster Tundra big motor, 4door crew cab. The radio OEM factory
    638-50647-NOA typical with CD.
    The issue: I can't turn the volume down at all. It is at full tilt for deaf folks. Turn on the radio and a blast of sound waves blows my hair back of what I have left.
    Tried most all common sense trying to adjust including stroking then pounding the dashboard
    Basically, no volume control. So can you assist me with this problem, I need every hair I have.
    Lamps
  2. Sep 21, 2021 at 12:54 PM
    lamps
    Russ
    2007 Tundra
    all original
    Thank you, On my way to give it a shot,
  3. Sep 21, 2021 at 12:56 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Try popping the knob off and rotating the piece underneath it.
  4. Sep 21, 2021 at 1:00 PM
    lamps
    Russ
    2007 Tundra
    all original
    No controls for radio on steering wheel.
  5. Sep 21, 2021 at 1:02 PM
    lamps
    Russ
    2007 Tundra
    all original
    I will now try the pop thing.
  6. Sep 21, 2021 at 1:08 PM
    lamps
    Russ
    2007 Tundra
    all original
    Tried to pop, NG At 79, and living 3 flights up take a bit out of ya.
  7. Sep 21, 2021 at 1:24 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would just replace the radio. The standard radio can be had used for about $100 and there are videos on YouTube that give sufficient details on how to pull the old one out. This is a job that requires a few screw drivers, a 10mm socket, and some plastic pry tools. I think you could do it in under an hour, even if it's your first time.
    The rotary encoder in your current head unit has probably failed, and it's just not worth the hassle to deal with replacing that single part.
  8. Sep 21, 2021 at 1:40 PM
    lamps
    Russ
    2007 Tundra
    all original
    Thanks, makes common sense to me. I thought it was a figermajiggy that needed direction or a hammer. Hammer wins.
  9. Sep 21, 2021 at 1:41 PM
    audiowize
    Paul B.
    joonbug and TRDFerguson like this.
  10. Sep 21, 2021 at 1:48 PM
    lamps
    Russ
    2007 Tundra
    all original
    Holly Mollie, looks like gremlins at work. Does anyone have a TOYOTA TUNDRA 2007-2012 FACTORY RADIO MODEL NO. 86120-0C182. A51829 for sale? I am ready for the task, have tools not to bad mind, just need the radio.
  11. Sep 21, 2021 at 1:57 PM
    lamps
    Russ
    2007 Tundra
    all original
    Great video, give me great inspiration to join Colledge of Bubs Incorporated, I wish it was in another Estonian dialect.
  12. Sep 21, 2021 at 2:18 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrĂĽeMax
  13. Sep 21, 2021 at 7:48 PM
    audiowize
    Paul B.
    https://www.ebay.com/itm/324758096483
    https://www.ebay.com/itm/334139148006?epid=6048812547
    https://www.ebay.com/itm/203609343678?epid=657379367
    I would offer $50 on the first one. You'd be patched up for ~$75, not too bad. Don't forget to oil your bar.
  14. Aug 17, 2023 at 6:06 PM
    Kenwood
    Kenwood New Member
    2007 Tundra
  15. Aug 17, 2023 at 6:08 PM
    Kenwood
    Kenwood New Member
    2007 Tundra
    Take the radio fuse out put it back in.
    I’ve had it happen 5 or 6 times with my 07 tundra. Fuse OUT / IN fixed it every time.
  16. Aug 17, 2023 at 6:13 PM
    TRDFerguson
    Jake
    2018 MGM CrĂĽeMax
    Stealing @bmf4069's pic
    blackdemon_tt and bmf4069 like this.
  17. Aug 21, 2023 at 3:57 PM
    walt3k
    walt3k New Member
    Which fuse is this one? I read the descriptions and it was not clear to me. thx!
  18. Aug 21, 2023 at 4:14 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Stolen, lol
    TRDFerguson[QUOTED] likes this.
