Can't get the key to link to the seat memory???
Discussion in '2.5 Gen Tundras (2014-2021)' started by lamikela1, Nov 9, 2018.
  1. Nov 9, 2018 at 7:52 AM
    lamikela1
    lamikela1 [OP] New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    I looked and can't find an answer to his one.
    My '19 Tundra Platinum has seat memory that supposedly can be linked to the key so that the seat returns to the memorized position when the door is unlocked with the FOB.
    The owners manual states...
    A desired driving position can be recalled linked with the unlocking of
    the door.
    ■ Registering procedure
    Record your driving position to button “1” or “2” before performing
    the following:
    Turn the engine switch off and close the driver’s door.
    While pressing the button “1”
    or “2”, press on the wireless
    remote control until the
    signal beeps.
    The driving position is recalled
    when the driver’s door is
    unlocked using the wireless
    remote control and the driver’s
    door is opened.
    To prevent unintended triggering of the alarm, open and close a
    door once after a driving position has been recorded. (If a door is
    not opened within 60 seconds after is pressed, the doors will
    be locked again and the alarm will automatically be set.)
    In case that the alarm is triggered, immediately stop the alarm.
    (P. 85)
    I've tried this several times and cannot get the key to link. Does anyone know the correct way to do this? I also tried using the door unlock switch on the drivers door as there are other Toyota models that use that instead of the FOB but that will not work either.
  2. Nov 9, 2018 at 7:55 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That’s cool if you can get it to work. Wonder if it’s the same on the 2nd gens. I’ll have to have my parents try it on there truck.
  3. Nov 9, 2018 at 8:10 AM
    lamikela1
    Michael
    So far everything that I tried does not work. Hopefully someone got it going.
  4. Dec 3, 2020 at 8:03 AM
    AZJack65
    AZJack65 New Member
    2021 Toyota Tundra Platinum
    I had to resurrect this thread because I believe I have found a solution for anyone else encountering this problem. I too followed the instructions in the owners manual perfectly with my 2021 Tundra Platinum. I figured out that it does work if you press the unlock button on the door and NOT THE KEY FOB. You do have to use the Key FOB you want to link the seat position too to unlock the truck and have it inside the cab while you work this procedure. I discovered this after watching a fairly recent video how to pair the FOB with a memory seat position in a Lexus.
    https://youtu.be/IlBgII9wfLQ
    thetastelingers likes this.
