CAN'T FIGURE IT OUT but its probably simple - blinker
Discussion in '2.5 Gen Tundras (2014-2021)' started by Unlimited, Mar 8, 2021.
  1. Mar 8, 2021 at 9:24 AM
    Unlimited
    Unlimited [OP] New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    Looking for some advice here, having issues with my blinkers.
    It started with a Zoolander issue - I couldn't turn left - without the front blinker not working. It blinks fast but would occasionally return to normal and even work. I replaced the bulb, noticing a bit of discoloration on the plug (but both sides have it, and at the time the right was working so I assumed it was normal). It began to work just fine for a few minutes, then returned to the fast blink.
    Now both sides don't work in the front at all, DRL's also off. Hazards don't hyper-blink, but don't work in the front either. I pulled the battery out and looked at all of the wiring, doesn't seem to be any issues and headlights are fine (evidence of a pinche raton so I thought wire might be chewed but doesn't appear so).
    Next step is to check fuses (I've already checked the one in the engine compartment) and check them all as I read on another blinker post that it could be a safety measure.
    People turning without using their blinker is my pet peeve, and I have a lot of built up anger occurring because I can't get mad and yell at them if my signals don't work either.
    Any suggestions????
  2. Mar 8, 2021 at 9:45 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Flasher relay maybe? It's in a little black box on the kick panel on the driver's side. You'll have to unplug the connector, unbolt the box and take it out. There's two little clips on the cover that let you pull out the relay.
    Image attached below. The two metal hoops are the resistors for the blinkers. I would look for corrosion or water damage or something. Should be obvious and maybe all you need to do is replace the module. You can get one for about $60 that will stop all clicking and fix led resistance problems.
  3. Mar 8, 2021 at 10:37 AM
    Unlimited
    Thank you I'll take a look at this
  4. Mar 8, 2021 at 10:59 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Make sure both bulbs are seated all the way down... common issue when bulbs are improperly seated is hyper flash and DRLs are off.. before going deeper push them all the way in first... its free.
    Occidentalis likes this.
  5. Mar 8, 2021 at 11:45 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Did you have led’s or the stock bulbs? If led’s they’re known to cause hyper flash. There was also a recall for certain years on the front blinkers......maybe check the recall website and see if you qualified
  6. Mar 8, 2021 at 2:28 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I also recently had this exact same issue.
    Push those bitches down until you hear a click,really!
    The bad one was also insanely tough to remove now that I think about it?
    Unlimited[OP] and blackdemon_tt like this.
  7. Mar 8, 2021 at 2:49 PM
    Occidentalis
    North Florida
    I hope it's as simple as the loose bulb! Good luck!
  8. Mar 8, 2021 at 3:21 PM
    Those bulb sockets do go bad due to the heat of those bulbs. On my 2013, the contact actually rusted out causing the bulb to not work obviously. Those sockets are about $10 each at the dealer. I put in new sockets and Vled Tritons and I was good to go. Makes sure the contacts are good and the bulbs are seated as mentioned. The recall mentioned was just for dimness.
  9. Mar 8, 2021 at 3:30 PM
    blackdemon_tt
    Usually, when you drive they'll start to jiggle like bitties and you will get random DRL on off like its winking at you, along with hyper flash... once snapped in place then its good to go.
  10. Mar 11, 2021 at 12:34 PM
    Unlimited
    Thanks everyone, I pushed them in really hard and that did the trick. I think the original actually burned out and then when I replaced them both I just didn't push it in hard enough. Appreciate the help
  11. Mar 11, 2021 at 12:40 PM
    Occidentalis
    North Florida
    Glad you didn't have to tear into anything!
    Unlimited[OP] likes this.
