Cannot dot Alignments driver side and passenger side
Discussion in 'General Tundra Discussion' started by Eddiede, Oct 24, 2023.
  1. Oct 24, 2023 at 10:11 PM
    Eddiede
    Eddiede [OP] New Member
    Eddie
    2004Toyota tundra four door 4.7 V8
    Every time I have read about someone asking how to time intake and exhaust cams with dots everyone starts trying to talk about the cam pulleys not the cam gears I don’t care about the timing belt at this point I want to know how to time the intake and exhaust cams on Both hands is it to Dr. to that on the driver side one that went out on the passenger side because like the guy said when he done that the driver side was 180 out please someone let me know thank you
  2. Oct 24, 2023 at 10:18 PM
    Eddiede
    Eddie
    1 dot to 1dot passengers side 2 dot to 2 dot on drivers side then rotate drivers side cam pulls clockwise till the marks line up on pulls 1 dot to1 dot on the passenger side cam gear the cam pulls timing marks line but the drivers side is 180 out
  3. Oct 24, 2023 at 11:48 PM
    If your profile info is accurate then you might get better traction in here --> https://www.tundras.com/forums/1st-gen-tundras-2000-2006.2/ instead of the general discussion area. The 1st gen guys are usually pretty happy to help if they can, but many don't wander outside of the first gen area.
