can you double tap a fuse? of help me find another place to tap! 2nd gen
Discussion in 'Lighting' started by Jwood562, Feb 8, 2021.
  1. Feb 8, 2021 at 11:22 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    hey guys, I have a second gen (13) and have already tapped my ignition fuse, using a add a fuse circuit for my 2020 sequoia headlight harness.
    I recently purchased a wiring switch panel and it requires an ignition fuse to be tapped to power the switch panel.
    So can I double tap the ignition fuse?
    or
    Is there another suggested fuse to tap for ignition power?
    Tundra2 likes this.
  2. Feb 12, 2021 at 8:56 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Oh wait...wrong double tap.
    I would use a fuse that typically turns on with the ignition. The cigarette or secondary power outlet fuse would work for your purpose. Those fuses are 15A.
    Looking at the fuse panel diagram for my 2021, the cigarette fuse is near the upper left corner. The secondary power outlet is near the bottom/middle left.
  3. Feb 12, 2021 at 9:39 AM
    Jwood562
    2013 Tundra 4x4
    Sorry forgot to clarify this is for under the hood fuse box
  4. Feb 12, 2021 at 9:42 AM
    Rockin 2nd Gen
    Rockin 2nd Gen New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
  5. Feb 12, 2021 at 9:46 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Is this going to power your switch panel or is it just a trigger wire to turn it on? If it is just a trigger there would be very little worry about the extra draw and I would just splice or tap into the other ignition circuit that you already have. If it is providing the power, you could splice into it and use a relay to push the draw to your battery.
  6. Feb 12, 2021 at 9:48 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
  7. Feb 12, 2021 at 9:55 AM
    Jwood562
    2013 Tundra 4x4
    Yes, it’s just the trigger wire. I’m using the six shooter system. I have it hooked directly to the battery right now but they don’t recommend keeping it this way
  8. Feb 12, 2021 at 10:00 AM
    APalmTree
    Brandon
    SW Washington
    It should be no issue to just tap it then. I'm running a switch panel under the hood as well and the trigger for mine is coming from the acc wire off my head unit that turns on my subwoofer amp. Kinda convoluted way to get there but there are no issues at all for a little over a year now.
