Can you adjust headrest front to back?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Mar 4, 2024.
  1. Mar 4, 2024 at 1:29 PM
    SDHNTR
    SDHNTR [OP] New Member
    I've looked in the manual and the only adjustment is vertical. I want to be able to tilt my head back more or wear a brimmed hat. Can you tilt the headrest back somehow?
  2. Mar 4, 2024 at 1:45 PM
    kapvu
    kapvu New Member
    2022 Tundra Platinum WCP
    I'm pretty sure it's vertical adjustments only.
    pwpblue likes this.
  3. Mar 4, 2024 at 2:06 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I don't know about the upper trims, but on the limited, it's only up and down. I miss the minimal, thin headrests of older vehicles. The average person today has terrible posture, verging on kyphosis. When I sit, I want to sit upright, not hunched forward.
    I'm still debating taking the driver headrest to an upholsterer to have foam removed and the material cut and restitched.
  4. Mar 4, 2024 at 2:09 PM
    SDHNTR
    Exactly! So lame.
  5. Mar 4, 2024 at 4:29 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    I'm too broke after buying this rig to afford mods.
    1794 here. Headrests are up/down only.
    Hella Krusty likes this.
  6. Mar 4, 2024 at 6:41 PM
    Robbsolid
    Robbsolid New Member
    Puyallup, WA
    2022 LTD HV WCP.
  7. Mar 4, 2024 at 6:59 PM
    Schneemann
    Schneemann New Member
    2023 Tundra CrewMax Limited
    I don’t have access to my truck right now so I can’t try it, but is it possible to remove the headrest and turn it around backwards? Due to the offset, that might gain a little more room.
  8. Mar 4, 2024 at 7:48 PM
    Nakedgun
    Nakedgun New Member
    Southwest
    2005 RCLB V8 4x4
    I been bugged by this "head-forward" aspect in Toyotas for some years, now.
    I remove the headrest and bend the steel posts enough to provide the level of comfort I need.
  9. Mar 4, 2024 at 8:18 PM
    Hella Krusty
    Hella Krusty New Member
    My wife has her Lexus headrest backwards because she wears her hair in a bun on work days and can barely drive otherwise
  10. Mar 4, 2024 at 9:08 PM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    Definitely going to try turning the head rest around in the morning.
    I considered trying to swap the rear headrest to the front seats too.
    It's incredibly uncomfortable as it comes from the factory!
