Can VIN tell me if I have tow package
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zum, Nov 9, 2018.
  1. Nov 9, 2018 at 10:13 AM
    Zum
    Zum [OP] New Member
    NS Canada
    I bought a used SR5 2014 DC, has tow mirrors, aftermarket electric brakes.
    He mentioned it had the tow package,so that would mean 4.3 gears , correct?
    Just curious if there is a way to look up VIN specs.
  2. Nov 9, 2018 at 10:16 AM
    Call dealer with your VIN# they can tell you
    15whtrd and Zum[QUOTED][OP] like this.
  3. Nov 9, 2018 at 10:45 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Called....tow package it has...thx again
    15whtrd and NewImprovedRon like this.
  4. Nov 9, 2018 at 10:48 AM
  5. Nov 9, 2018 at 10:51 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You can also email the vin to Toyota customer service. They will email complete spec list. I did this for a Rav4 that I bought my daughter.
    15whtrd likes this.
  6. Nov 13, 2018 at 7:21 AM
    nodak67
    nodak67 New Member
    JR
    vin will not actually show what packages are with the vehicle using a decoder. they have to do a vin lookup in dealer daily to see what options/pkg are added to the vehicle.
    since the tow package is an option that is either installed at the port (PIO) or at the dealer (DIO). usually DIO stuff is wont show on the Mulroney where a PIO will show on the Mulroney.
    if I remember correctly the tow package is labeled as "TO" option/pkg code unless it is standard equipment with the trim level.
  7. Nov 13, 2018 at 10:17 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
  8. Nov 13, 2018 at 2:26 PM
    Zum
    Zum [OP] New Member
    NS Canada
    I tried that site, it didn't mention if my truck had the tow package. I didn't sign in though and my "print out" didn't look like yours. When I called the Toyota dealer , they only needed the last 8 digits. Reason I wanted to no is, I replaced my ring and pinion assembly( old one was noise "whiny" at certain speeds) and wanted to make sure the right one was ordered. No noises now, next thing is suspension, maybe a little level.
  9. Nov 14, 2018 at 10:10 AM
    nodak67
    nodak67 New Member
    JR
    SR/SR5 the tow package is optional
    limited, plat, 1794, pro it comes standard.
    so if you pull a vin from a SR/SR5 it wont tell you if it comes with a tow package or not unless you lookup via dealer daily to see what options it has.
    and using a vin from a limited, plat, 1794 or pro will always show a tow package since its not tied to a vin. it comes with the vehicle regardless.
    and in case you are wondering, that screenshot is from a plat/1794 since those are the only models that get a 12-way seat as standard.
    Wrongside and Zum[OP] like this.
  10. Nov 14, 2018 at 2:47 PM
    Azblue
    The Dirty T ( ^_^)_且
    If the truck is a 2014 or newer and has the 5.7, it has the tow package. It's standard on 5.7 equipped trucks.
    Before 2014 it was an option.
    dak13 and Zum[OP] like this.
  11. Jan 27, 2024 at 9:39 AM
    beaverPilot89
    beaverPilot89 New Member
    Thanks for the help on this thread, came here because I purchased a 2014 1794 at auction and it will arrive in 2 weeks. I cannot see from the photos if it has a Factory Brake Controller and we have a trip coming up once it arrives.
    Did the 2014 1794 Edition Include a Factory Brake controller? I have watched all the youtube reviews and nobody seems to mention it.
    If it did not include one, has anyone got a Redarc to work with the 2014's semi-unique wiring, Or only the Tenkosha
