Can this tree be saved?
Discussion in 'Outdoors' started by aRabidLunatic, Apr 24, 2020.
  1. Apr 24, 2020 at 6:11 PM
    aRabidLunatic
    aRabidLunatic [OP] Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Guys, probably a dumb question but is there any point in keeping this tree? The whole top half is dead.
  2. Apr 24, 2020 at 6:12 PM
    Azblue
    The Dirty T ( ^_^)_且
    I'm no arborist, but I don't think so.
  3. Apr 24, 2020 at 7:13 PM
    Sunnier
    Sunny
    San Diego, CA
    If only the top half is dead as it appears in the pic, you could cut it off above the top limb that is still alive, then wait and see. Not to be funny, but I could say that would be about 50/50 that it would survive.
    That said, it depends on why it’s not healthy. If it has a parasite (mine had a beetle), it probably won’t survive.
    Boerseun, GODZILLA and HappyGilmore like this.
  4. Apr 24, 2020 at 7:21 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The dead part needs to be cut off. You may not like it much after that.
    I would be prone to replace it with something that thrives in your area.
  5. Apr 24, 2020 at 7:35 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    If it is any type of ash, no way. I had one die because of the Ash Bore.
    Sucks.
    Rica25 likes this.
  6. Apr 24, 2020 at 7:39 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Depends on why it’s dead. If it’s a parasite then probably not. Check for beetles and parasites either way you’d have to remove the absolute dead portion and correct what caused its to die to begin with.
  7. Apr 24, 2020 at 8:42 PM
    aRabidLunatic
    Central Texas
    I don't think I watered it enough. Had another tree of the same kind die in the backyard
  8. Apr 24, 2020 at 9:27 PM
    Slayer
    Slayer Member
    Slayer
    trees typically die from the top down.
    I'd say she's a gonner
    ..Slayer
  9. Apr 25, 2020 at 5:37 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    That appears to be a fairly young white oak tree. Young trees, even old trees, will require watering when it doesn't rain. It's becoming an issue even for wild trees in Texas.
    The new leaves that came back look healthy now, so I would give it another year. Starting at the very top, prune all the dead wood off. You'll also want to prune away all those trash suckers coming up from the base. Check the top central trunk closely to confirm it's dead before you prune the central trunk back. If you have to cut off the central trunk, then that tree is done. It will always be a squatty, misshappen bush...replace it.
    Scratch a small place in the tender bark of branches without leaves down to the wood core. If the inner lining of the bark is green, that area is NOT DEAD. If it's brown and dry, prune it off cause it's not coming back. If the tree continues to die back this growing season, then it has a problem and will probably be dead next year anyway. Water it well this spring/summer.
    Toyotoholic, Wallygator and Sunnier like this.
  10. Apr 25, 2020 at 5:41 AM
    War Machine
    War Machine SSEM # 5 3MW
    I prefer to look at it as half alive.
    Sunnier, Trooper2 and GODZILLA like this.
  11. Apr 25, 2020 at 5:43 AM
    18" TRD Off Road Wheels
    Jpneely likes this.
  12. Apr 25, 2020 at 5:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    R&R that tree.
  13. Apr 25, 2020 at 6:32 AM
    aRabidLunatic
    Central Texas
    Thanks everyone, going to dig it out today
  14. Apr 26, 2020 at 2:47 PM
    Wallygator
    You could wait until Christmas and do a Charlie Brown theme in the yard using that tree as a real Charlie Brown Christmas tree...
    Rex Kramer and GODZILLA like this.
  15. Apr 26, 2020 at 2:58 PM
    Rex Kramer
    Georgia
    Explosives are quicker.
  16. Apr 26, 2020 at 2:59 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Saved for firewood :D
  17. Apr 26, 2020 at 3:05 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    Bend the branches a little. If they break off easy and are dry inside, it’s dead. If not, it’s not fully out of its dormant stage.
    if the top part is dead, just cut that off and it will continue to grow.
    Jimes likes this.
  18. Apr 27, 2020 at 1:01 PM
    aRabidLunatic
    Central Texas
    Ended up taking it down. Thanks everyone!
