Can the rear view mirror be raised?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Sep 6, 2018.
  1. Sep 6, 2018 at 10:35 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I have a 2015 Tundra 1794 crew-max is there a way to raise the rear view mirror
    I am 6'-4" wish i could adjust my mirror a little more.
  2. Sep 7, 2018 at 6:17 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Lower the seat ghetto style.....?
  3. Sep 7, 2018 at 6:43 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    If it is the same as the 2018, then there are 2 ways to raise it. I am also 6'-4" and my mirror sits almost flush with the headliner.
    The mirror is attached to the windshield, so technically when they replace the windshield they have to remove and re-attach it, so you should be able to remove and re-attach it higher without replacing the windshield - just figure out how they do it - I assume double sided tape. (I have not done this - not needed)
    Also,
    The stalk has two pivot points - one at the windshield and one at the mirror, so you can swivel the one at the windshield up as high as possible and then tilt the mirror back down at the swivel behind the mirror. That's how mine is and as said above it is almost at the headliner.
    I tried to take pictures but the way it sits in the sun I was not able to get anything without a lot of glare.
    kcaustin66[OP] likes this.
  4. Sep 7, 2018 at 9:07 AM
    kcaustin66
    kevin
    Seat is as low as possible now
  5. Sep 7, 2018 at 12:00 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Lay the seat back and throw that ghetto lean.......
    jewsNbrews likes this.
  6. Sep 7, 2018 at 12:07 PM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I had a mirror relocation bracket in my tacoma that a member at tacomaworld.com used to make and sell. It moved the mirror mount up by about 2". Tried it on my Tundra and there wasn't enough clearance between it and the headliner to work easily. I'll have to revisit that if I can find where I stashed that bracket.
    Also, the adhesive for the bracket is a 2 part epoxy that you can buy at any auto parts store.
