Can the radio stay on after turning motor off...?
Discussion in 'Audio & Video' started by Drifthopper, Jun 24, 2020.
  1. Jun 24, 2020 at 5:23 AM
    Drifthopper
    Drifthopper [OP] New Member
    '20 Limited Double Cab Silver Sky
    2020 Limited.
    Push button start
    all stock / factory radio
    So....I'm listening to the radio, news,,, whatever.... and when i back into the garage, i"ll hit the button to turn the truck off and the radio goes off too...! :annoyed:
    I looked in my manual, audio manual, quick start guide, scrolled thru the old topics in here, but can't find anything.
    Can the radio be programmed to stay on after the truck is shut off but go off when the door is opened....? :confused:
  2. Jun 24, 2020 at 5:28 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Push the button while you are still in gear. It’ll shut the motor off but leave accessories running. Then shift to park
    that’s how it worked on my lexus and Tacoma. I assume the tundra is the same
    Drifthopper[OP] likes this.
  3. Jun 24, 2020 at 5:32 AM
    Drifthopper
    ss.....I'll give it a try. :thumbsup:
  4. Jun 24, 2020 at 6:13 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    If above doesn’t work, When the truck is off you should be able to turn the truck’s ACC on without starting the engine by hitting the button with your foot off the brake.
  5. Jun 24, 2020 at 6:20 AM
    Drifthopper
    ZR...True... but then ya gotta go thru that 30 second start up procedure, which i'd like to eliminate.
  6. Jun 24, 2020 at 8:55 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    Not my Tundra, buy my Mazda, put in Park, press brake pedal and shift button on shifter, then push on/off start button. It turns motor off and leaves on accessories. Try it, see if that works.
  7. Jun 24, 2020 at 7:11 PM
    Drifthopper
    After driving around today..... if i put it in park, hit the button, turn the truck off,hit the button again, it takes 16 seconds for the radio to come back on.
    When the truck is in gear, hitting the button, motor goes off, radio stays on, then ya gotta hit the button again to turn it off.
    I guess that'll have to do.... turn it off in gear to listen to the radio when getting out of the truck. o_O
    shellshock likes this.
